Old 12-23-2015, 07:24 PM   #71
Kenny kustom's Avatar
Originally Posted by northstar1960 View Post
Why ? completely safe , no worse then the furnace or wave type heaters . it's very common in Europe . look em up and see for yourself
Probably something to do with the open fire in an rv, that would go up like a match.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-23-2015, 08:02 PM   #72
northstar1960's Avatar
2016 Sabre 36QBOK
I am nice!
It's not an open fire . it's in a wood stove . better and thicker box then the furnace tubes that have fire going through them in side the RV .
northstar1960 is offline   Reply With Quote
Old 01-04-2016, 09:42 PM   #73
mark.g's Avatar
Has anyone modified the duct to the garage to make it a full 4"? If so, do you have any pictures/insight you could share?
2016 XLR Thunderbolt 415AMP
-Progressive Industries EMS-HW50C, SteadyFast Stabilizers
2005 Chevrolet Silverado 3500 6.6L Duramax
-Hillsboro Flatbed, Dakota Hills Truck Defender Aluminum Front Bumper, S&B Cold Air Intake, AirLift Load Lifter 5000 Ultimate, VIAIR Medium Duty Onboard Air System,
mark.g is offline   Reply With Quote
Old 01-05-2016, 10:38 AM   #74
WolfWhistle's Avatar
I did the nothstar99 furnace mod and don't heat the garage unless I do it with an electric heater.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 01-05-2016, 10:41 AM   #75
The mod makes the supply side of the furnace what was the return. This heats the main cabin well... blowing straight out from the furnace.
WW
Old 01-05-2016, 05:28 PM   #76
Homebrew's Avatar
WW
Does heat come out the floor vents with this change? Or just from the return?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 01-05-2016, 05:54 PM   #77
Our Hyperlites (mine a 29HFS as you see) doesn't have floor vents; all supply ducts are cleverly routed through and within the main cabinet in the kitchen and bath... one facing the bedroom; facing into the living room; along that cabinet and below the fridge into bath cabinet register; then through the wall into toy bay to that vent. Clever but not enough vents, air flow or enough furnace BTUs. With the mod which makes the return the supply; I can feel the old supply registers acting as returns. But, air can get back via any opening into the cabinetry.
The mod is removing the supply ducts from the plenum; leaving them in that space, covering those holes, replace then return vent door with a register, while sealing the space between the plenum and register with aluminum and aluminum tape. All the heat gets to the room without wasting heat inside the cabinets, or within the ducts. I also blocked off the garage register entirely.
For me the furnace is for extreme (ha!) lows, with an electric space heater or two primary and a Wave6 backing them up or when not on shore power.
WW
Old 01-13-2016, 07:10 AM   #78
Hey PH, any updates on the furnace change?
DennisTD is offline   Reply With Quote
Old 01-13-2016, 05:11 PM   #79
Play Harder's Avatar
Funny u ask today the answer is NO
My toyhauler is still at the repair facilities waiting on XLR -
I'm not happy!
Play Harder is offline   Reply With Quote
Old 01-13-2016, 07:30 PM   #80
Sorry to hear!
light, vent, xlr
