Old 08-22-2014, 01:53 PM   #1
Heated underbelly
Does anyone know for sure if the 29hfs has a heater underbelly? I know there is a package for heated holding tanks, but that doesn't help with the water lines, etc.
mjost is offline   Reply With Quote
Old 09-03-2014, 06:51 PM   #2
It is only insulated and not heat. All tanks are incompassed in spray foam and covered with the belly shield
Go leafs Go is offline   Reply With Quote
Old 09-09-2014, 04:17 PM   #3
WolfWhistle's Avatar
My 29HFS "had" only coroplast belly.... no insulation under floors... nada on or around tanks. I thought of adding the tank heaters, but elected to be cheap... when I had the belly off I insulated the floor with Reflectix (stem to stern), wrapped water lines and sealed it all up with tape and foam.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
underbelly
