Old 01-26-2013, 08:13 AM   #41
RVChick's Avatar
Hi Danno2u....we are doing fine, thank you asking! It was a bit rough earlier this week when the temps went down to 13 and 16 degrees overnight. I kept a space heater on in the cargo area and closed that door, then a space heater in the coach and one in the bedroom. Closing the bedroom doors at night kept it nice and warm. During the day I keep the shades closed if the sun is not out. We have someone from a place called Rec Tec that is sending a guy out next week to fix everything. They are letting him do it as a side job, since we are parked a bit out of their way. Rec Tec did all our RV work on our old unit, and they have knowledge of all kinds of RV's. They always gave us great customer service before, and now they are continuing that service. The guy is waiting on parts for the furnace so that he has everything he needs in case it is a problem we don't anticipate. He is also going to fix the fireplace receptacle so that I can use the fireplace too. (We had the motor replaced a week after we bought the unit, but the receptacle was bad and did not allow the plug to fit snugly when plugged in. So to avoid a possible fire in that panel, we have had it unplugged all this time. (We tried to plug it into the outlet for the TV but it trips the breaker. The fireplace plug is on its own fuze.).
I will be so happy when the furnace is more wearing long johns all day long!!
Kenny n Karen
TV: 2007 Chevy Silverado 3500 DRW - named Alice
RV: 2012 XLR Thunderbolt 35x12 - named Thor
RVChick is offline   Reply With Quote
Old 01-29-2013, 07:05 PM   #42
Plug32's Avatar
Lock-out & Reset
Newer furnaces may go into “lock-out” if a potential safety problem is detected. Lock-out simply
means that the Control and/or ignition circuits shut down and do not allow furnace operation.
Lock-out can be reset by turning the thermostat switch off and changing the Set Temperature to a
low enough value so there is no demand for heat and waiting 10-15 seconds. Then turn the
thermostat on and set the temperature to the desired level and the furnace should attempt to start
Plug32 is offline   Reply With Quote
