Old 05-02-2015, 06:54 AM   #1
Heater operation?
Hello, first time for the need to use the suburban heater. I am not 100 percent of the correct operation. ( the manuals are not so clear) I appreciate your comments
I turned on the propane, turned the themostat to heater, put on 65 degrees and the unit started to produce heat through the beige vents, but The ac unit also turned on and it is blowing cooler air, not cold but it is pushing out air through the white vents . Is this normal?
What do I need to watch out for using the heater?
To speed the process I also turned on both burners on the stove but it kicked off the fire alarm, so I turned them off and the alarm did not sound again.
laurajean is offline   Reply With Quote
Old 05-02-2015, 06:58 AM   #2
HONDAMAN174's Avatar
Turn your t-stat to the fan mode- then press + or - to put it into "auto" fan control. That's it. Select heat and good to go.
Just glad to get away
Old 05-02-2015, 07:00 AM   #3
wmtire's Avatar
Hondaman174 got you fixed up. You need to have it in 'auto' mode.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-02-2015, 07:01 AM   #4
Great...the fan turned off and we only hear the heater blower. Thanks very much for the help!
Old 05-02-2015, 07:32 AM   #5
Uh...am I still drunk? Oh well...that's what I was trying to say 😜
heater
