Old 09-28-2015, 06:40 PM   #1
Heating, AC question
This weekend we actually used the heater for the first time, in our 27hfs, but for some strange reason the AC unit also turned on and wanted to run at the same time, while I shut off the ac unit at the breaker I was wondering if this was typical for the ac to run at the same time even though the heater an AC are 2 separate systems.
Berjr1 is offline   Reply With Quote
Old 09-28-2015, 06:45 PM   #2
oldgold's Avatar
Just the fan is running thru the AC vents. Your AC shouldn't be running. This is a feature of the XLR. You can change at the thermostat to running on auto when the heat kicks on or running fan full time while the heat is on/off. Similar function to normal AC operation. We keep the fan on full time while heating or cooling to keep the temp even across the camper. Plus the fan turning on and off all night doesn't help keeping the young one asleep.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 09-29-2015, 01:26 PM   #3
Thank you I will look at the thermostat a little closer but i didn't see and auto setting just the multi switch for On/Off/Mode and the +/- for the temperature setting The fan running through the AC unit is much too loud for me i would prefer it to be off all the time. this is the thermostat we have
Dometic 3313192.019 Black Single Zone LCD Thermostat Only Camper Trailer RV
Old 09-29-2015, 01:32 PM   #4
oldgold's Avatar
I have the same thermostat. I think hit the mode button and cycle up to fan. Then use the +/- buttons to change setting. I could be wrong, I'm used to not thinking about it. Trying to remember.
Old 09-29-2015, 01:33 PM   #5
fonzie's Avatar
Here is manual...page 8 and on
File Type: pdf Dometic Thermostat- Single Zone Digital.pdf (1.40 MB, 119 views)
Fonzie
Old 09-29-2015, 03:38 PM   #6
Thank you
I will check it out the instructions help a lot too ill be setting it to auto
thank you Old Gold and Fonzie
Old 09-29-2015, 04:07 PM   #7
oldgold's Avatar
No problem.. I'm stuck in an airport and just cruising the forum. BORED OUT OF MY MIND!!
heating
