Old 09-29-2014, 10:30 PM   #1
Help needed on an xlr viper
Dumb question but can somebody tell me how to drain the fresh water tank on an xlr viper 345? Thank you ahead of time for any input.
Also with the tv. I was able to pick up 20+ channel off the antenna at the dealership but after watching a movie and moving the unit it will not pick up a signal. I have done the obvious like ensure the antenna was up, check to ensure tv signal booster was on (green light on), and tried each input setting with no luck. Any suggestion?
nhrangerjoe is offline   Reply With Quote
Old 09-30-2014, 08:40 AM   #2
Donnieburnett2's Avatar
Did you run the channel search again? When you move to new local, you would need to preform this act each time for the best results
Donnieburnett2 is offline   Reply With Quote
Old 09-30-2014, 08:59 AM   #3
Witch Doctor's Avatar
Are you on over the air antenna in the menu and not cable? Also you need to re scan, I try to move my antenna in 1/4 increments and scan If I don't know the tower location, When I start to pick something up I fine tune it. By the way which one came with your unit. How far are you from a major city with a tower? don't have XLR, but most drains are just little pet cocks under the tank location.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-30-2014, 04:56 PM   #4
Taranwanderer's Avatar
My FW tank drain is a blue hose with a black screw-on cap, not a petcock. In front of the wheels on the hfs-5, but not sure where on your viper.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 10-02-2014, 10:29 AM   #5
Thank you for the input I will give it a shot when I get home this weekend
xlr
