Over this past weekend was our first trip out in our new Leprechaun 317 C class. The fridge took a while to come up to temp, but I also found that the "slide" that's used to make it colder had slipped down being pulled down by the little thermostat tube attached to it. I reconfigured it to make sure it stayed put and Voila! COLD!
Our AC was tripping the breaker too, I finally turned off the Elec Hot water heater and used the gas side to heat up water for a shower, then turned it back off. No more tripping!
HOpe you had a great time, I know we did!
Patrick & Stacey Burnett
Central Arkansas
2013 Coachmen Leprechaun 317SAF
1998 Seaward Fox Cat rigged trailerable sailboat
Our Lake Life Blog
