10-24-2016, 12:27 PM
Hey did you know the awning is spring loaded.
Had to take the awning off because of wind damage and couldn't get it rolled up. I found out the awning is spring loaded.
10-24-2016, 12:29 PM
Ouch.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
10-24-2016, 01:02 PM
Ouch, hope that heals quickly.
Yes they ARE spring loaded and every awning manual I've seen through the years have had a warning as such.
Here is a page from the Dometic electric awning manual with no less than THREE paragraphs of warnings about the awning being under spring tension.
I added the red box.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-24-2016, 05:17 PM
I found out the same way you did. I was lucky and only have a black finger nail.
2017 Alpine 3401RS,Titan Disc,Morryde SRE 4000, 2016 Ram 3500HD Laramie SRW,LWB,4X4, Aisin transmission
10-24-2016, 05:23 PM
Like a roll up garage door... Nothing to fool with either. A garage door spring will kill you, right now.
10-24-2016, 07:50 PM
Ouch! That's a painful way to find out. The cut looks deep.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
10-24-2016, 07:56 PM
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
10-24-2016, 08:03 PM
When I installed my home built awning poles I used the awning bolt for the forward attach hole on the bracket. Prior to removing the bolt I clamped the awning in place with a vice grip type "C" clamp. Worked great.
BIRDS AREN’T REAL
10-24-2016, 08:10 PM
Both the motor and the torsion end are held in place by the channels in the arms, the bolt is just to hold it in place and does not keep it from spinning.
10-24-2016, 08:34 PM
Which brand is that. The LCI Solera model is not like that. Remove the bolt without securing the roller will let the whole thing fall out.
BIRDS AREN’T REAL
10-24-2016, 08:39 PM
Ouch, how many stitches on that pinky finger? Looks like it stopped bleeding?
2015 F-250 FX4
10-24-2016, 08:41 PM
Dometic/A&E
10-24-2016, 08:54 PM
Newb
Owie, I had a garage door spring break once luckily no one was near it.
What a pain to fix.
01-09-2017, 04:38 PM
I hope you are all healed up.
Did you find out what brand your awning is? I have the same one on the trailer I am bringing home tomorrow and it does not work and I need to see if I can find a manual for it.
2011 GMC Duramax/Allison
2013 Puma 356QLB
Days Camped 33
Miles 6450
