08-14-2015, 05:00 PM
Hot water heater not working on electric
I have a brand new XLR Thunderbolt and I have no hot water I haven't tried propane just electric. I have turned the switch on outside and check the bypass and pressure relief valve still nothing is there any other switches I am missing?
08-14-2015, 05:10 PM
I had this happen to me. I found it was unplugged (electrically). Remove the service panel, on the inside of the trailer, to gain access to the WH. There should be a dedicated outlet next to the WH. My guess is, if brand new and never worked, you'll find the cord coiled up and unplugged. 👍🏻
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
08-14-2015, 05:34 PM
John513
Sure you already know this, but you did fill water heater and run water to bless the air out before turning switch on right. There is also a reset towards top of heater. There are two resets that are covered with a large rubber boot. One is gas reset and other is electric.
08-14-2015, 05:35 PM
John513
Sorry not bless, but bleed.
08-14-2015, 05:36 PM
I prone to believe it is not plugged in I have checked the resets and bled the air I will remove the panel when I get home and check the plug.
08-14-2015, 05:41 PM
In the remote chance that you plugged into shore power before filling the tank, you may have burned the element out. It only takes about 10 seconds of power with no water to burn it out. Hopefully it is just not plugged in.
08-14-2015, 05:46 PM
I didn't turn the switch on until I bleed the hot water heater and all of the lines.
08-14-2015, 06:06 PM
It does happen a lot that the heater is not even plugged into an outlet. As suggested check that scenario. Also make sure the breaker in the electrical panel tot he water heater is on.
Are you using the pressure relief valve on the water heater itself to verify there is water in the heater....or just the turning on the hot water taps?
It's also common for the bypass valve to still be in the wintering mode, and thus you will get cold water out the hot water line, since they are tied together in this state.
One last thing, it takes a little bit for the electric heating element to heat the water...about twice as long or more than propane
This may help:
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
08-14-2015, 06:19 PM
I have a random question.. Does the switch inside turn off the switch outside? Ex.. If the switch outside is on and the switch in the camper is off, is the heater off? Or is the switch inside just for the gas?
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
08-14-2015, 06:22 PM
Inside gas, outside electric
2019.5 Rockwood 2509S
08-14-2015, 06:33 PM
Good thing I've been shutting them both off.
08-14-2015, 09:56 PM
On mine the dealer turned the breaker off to remind me to make sure the water was on first.
2016 Hyper Lite XLR 30HDS
08-15-2015, 06:05 AM
My buddy's non-FR product has a switch for the electric both inside and outside. Both have to be "on." But if you only have one switch inside, it's for the gas burner.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
08-15-2015, 04:18 PM
On my rig inside switch is propane only. Outside switch electric only
08-15-2015, 04:35 PM
There is also a breaker labeled Water Heater.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
08-15-2015, 05:43 PM
08-29-2015, 10:29 AM
Update on my hot water heater it was unplugged!!!!
08-29-2015, 11:39 AM
-R.Jones
Nitro 31FQSL
A good tip from Aug. 14.
08-29-2015, 08:35 PM
Wonder if they are shipped unplugged and the dealer plugs them in? Or is supposed to?
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
08-29-2015, 08:45 PM
When I spoke to Diane of FR she said it was the dealers responsibility. It's generally done during the PDI.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
