01-27-2013, 01:28 PM
How do you tell when fresh water tank is full?
How do you tell when the fresh water tank is full- when you are filling it up? The manual says that they have a small hole that will shoot out water to let you know. Mine does not. What happened was it filled up the tank then filled up on top of the underbelly covering and then finally started pouring out around the edge.
What am I supposed to do? Stay inside and watch the LED indicator on the control panel?
01-27-2013, 01:35 PM
You should have a vent hose coming coming out the top of your tank, that allows air to escape and water will come out when tank is full. Sounds like maybe your hose has come off, or possibly was never attached at all.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
01-27-2013, 01:47 PM
When I fill my freshwater tank it means I'm getting ready to boondock/dry camp. I fill it until it overflows!
01-27-2013, 02:03 PM
I fill mine very slowly............... 20 minutes or better to fill.
I trickle it in till it starts gurgling back out.
my ole flagstaff I had to do that anyway so I just continue to do it the same.
TURBS
01-27-2013, 02:04 PM
Same here, I fill it until it overflows.
01-27-2013, 03:31 PM
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
01-27-2013, 03:44 PM
Pretty sure everyone fills until it overflows, but if your overflow is dumping into your covered underbelly, as the OP stated, you have a problem.
01-27-2013, 03:52 PM
I bet theres a hose covered by silicone he's not seeing.
To the op ...... right next to where you fill is there a small mesh looking screen close by ?
01-27-2013, 03:55 PM
is your fill like this ?
01-27-2013, 04:04 PM
My overflow tube actually comes out through the bottom of my underbelly, right next to my FW tank drain. When it pours out it's full. My last TT had vent tube right next to fill though.
05-24-2013, 08:03 AM
Was just wondering when I fill my water tank mine drains out the bottom to tell me I'm full I get that. My question is when I'm hauling it the movement and flex makes water pour out of tank and when I stop it stops. But if I travel to far will it just keep pouring out or should I plug it while I'm moving than unplug it when I park so tank can breath? Any help would be great
Thanks Sam 2581
05-24-2013, 08:26 AM
Thanks Sam 2581
Don't think you have anything to worry about, it's just the sloshing motion of a full tank. Once the water level gets below the vent, it will stop or at least slow down and stop when you stop the vehicle.
05-24-2013, 11:55 AM
I have an XLR 35 x 12 and travel 5 to 12 hours a trip. By the time i get to where im going i was losing 20-30 gal of water because of the sloshing around, now i fill it till it comes out the overflow then bend the rubber overflow line in half and ziptie it till i get to where im going.
05-24-2013, 12:03 PM
I put a shut off valve at the end of my vent vent hose and just close it when travelling.
Tim and Bev
2013 Cedar Creek 34RLSA gone trying to find my way back, Magnum 2800w inverter, 560w of solar.
2020 F-350
05-24-2013, 12:15 PM
daydreaming about camping
Thanks Sam 2581
well - I lost about 1/3 of a tank to sloshing on a trip. Was heading to a state park that did not have water at campsite so filled it before I left. Was VERY surprised how much of the tank sloshed out.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
05-24-2013, 12:47 PM
ive never had this problem........... I wonder why ?
turbs ?
05-24-2013, 12:53 PM
Originally Posted by f1100turbo
ive never had this problem... I wonder why? turbs ?
Me either, but we rarely, if ever travel with over 5-10 gal in the fw tank.
05-24-2013, 02:58 PM
Thanks for the reply's guys I think I'm just going to put shutoff Valve on and close it when traveling , and open when I get setup to camp to let it vent . I have a 25rr 2014 and this will be my first time out today, have fun everyone !!!!
Sam2581
05-24-2013, 04:37 PM
I have a vent like the small mesh one pictured, but mine has never had water come out of it. My tank overflows from the bottom of the tt.
05-24-2013, 04:48 PM
Phat Phrog Stunt Crew
Here is a good thread covering this and a fix for it..
http://www.forestriverforums.com/for...8ts-13039.html
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
