Old 02-21-2016, 09:30 AM   #1
How to attach stuff to the wall?
Hi, I am new to RVing.How is RV build? Are there studs in the wall every 16" or 24"? I would like to attach few things in garage.
Also how do I attach grill to a propane tank?What hose will I need?
Thanks for your help.
2016 Hyper Lite XLR 30HDS
2015 GMC Sierra Denali 3500 DRW
GMCdiesel is offline   Reply With Quote
Old 02-21-2016, 09:39 AM   #2
Ford Idaho's Avatar
For the wall, we have used the Velcro and hooks with great luck.
https://www.google.com/aclk?sa=L&ai=...oad_%2Bcommand
Walmart/Sam's Club.
What grill?
Gas from the trailer is regulated, if you use a Coleman type it has a regulator and the combination will reduce the gas pressure to the point of being useless.
Old 02-21-2016, 09:40 AM   #3
Kels4g's Avatar
We use command strips to hang stuff like pictures, decorations, etc. The walls don't seem to be able to really hold much weight at all based on when my husband accidentally put a hole in the wall- there is nothing there.
I can't answer about a garage because we don't have one.
Kelly and Stephen with Daisy, Lily, and Roxy!
Run Free Sweet Riley 2009-2015
Visit our blog for more information and details!
www.kels4g.com
Kels4g is offline   Reply With Quote
Old 02-21-2016, 07:07 PM   #4
Walmart/Sam's Club.
What grill?
It is Weber Q 1200, it use 1 lb. cylinders.
Old 02-21-2016, 09:29 PM   #5
rracer5's Avatar
I just carry an extra 20 lb (5 gl.) propane tank and hook to my Weber with this; 5' Propane Hose Assembly - Mr. Heater F273703-60 - Propane Hoses and Adapters - Camping World.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-21-2016, 09:31 PM   #6
TURBS's Avatar
I use this to secure my extra 20lb tank.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-21-2016, 10:59 PM   #7
Usually Confused Member
emm-dee's Avatar
I'm not familiar with your camper but you can probably use a "stud finder" to locate the wall supports (providing they're wood). If there is no stud to attach something heavy then an old fashioned molly bolt that has the spring loaded folding arms that pop out once you push it through the drilled hole works well.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 02-22-2016, 11:22 AM   #8
D_B Travelers's Avatar
x2 on the Velcro. We put a Command hook at the top for the picture to hang from, then put regular a Command sticky velcro at the bottom so they will not vibrate off the hook. Pretty good luck so far with this system. Heavy pictures or items may require a couple of hooks and pads in case you happen to encounter a pothole on our nation's highways.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 02-22-2016, 11:27 AM   #9
Command strips are awesome. We put some up over 5 years ago & they're still holding firm. We do take our clock off the wall before we travel, just in case it bounces too much, but we may modify it to D_B Travelers method of some velcro at the bottom, so we don't have to keep taking it down.
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 02-22-2016, 11:30 AM   #10
AquaMan's Avatar
If you look at the outside of your camper on a cool dewy morning, you will see all the frame structure. There is no real rhyme or reason behind where a framing stud may be, other than the least amount to make it structurally sound.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
