Old 08-10-2016, 10:26 AM   #1
WolfWhistle's Avatar
husky 4500 tongue jack; not so husky
I suppose the pipe is bent, but it has never been drug or hit the ground. I always chock before lifting hitch from ball. So I find that I can replace the lower structure for $150. Shopping around I found an Ultra Fab 4002 complete and new for the same money. Its rated for 4000# and looks better than the Husky ... has grease fittings.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 08-10-2016, 10:37 AM   #2
photo. Tried greasing it , which helps but no cigar. I can see the bend ... tried to pull it out with come-a-long ... helped sone ... but figured I would just bend it in another place and accomplish nothing.
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
Old 08-12-2016, 11:01 AM   #3
WW,
I can barely see a bend. Is it binding up on you or are you just being preventive? Hate to see anyone spend good money when something is not broken....
2015 XLR Hyperlite 29HFS (installing mods...)
2004 GMC 2500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 08-12-2016, 01:12 PM   #4
Originally Posted by stevejd235 View Post
WW,
It binds pretty bad. At the campground, it refused to go down (raise the leg) enough to leave ... took off the TJ... after breaking a strap trying to pulling the bottom forward. The last time I tried it and after the grease worked in, it would go all the way down, almost normally, but lifting back up, it sounds bad; slow; and it sounds like gears are about to go away.
I want to throw it out until I've at least tried to straighten it.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
Old 08-13-2016, 03:13 PM   #5
Canadian Member
itat's Avatar
Lots of folks here swear by the Barker brand electric jacks. But my Husky Brute HB4500 has performed flawlessly so far.
This is not your only problem. The L brackets for your Equal-i-zer bars are creeping. They should be at 90 deg. to the frame. You'll need to add a shim of some type. I had the same issue on my Roo.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 08-13-2016, 04:15 PM   #6
thanks itat, I figured Baker is the Cadillac but in this case I went with the least expensive. I think the Husky was bent during a Texas storm that nearly blew the trailer over. But I've used it since and only recently has it acted up. So I'm not ruling out WW fault. Oh, and those brackets are different than Equalizer... they're Anderson which are designed this way; there's a setscrew tapped through the frame; nothing has slipped in over 4000 miles.
thanks again WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
