03-15-2016, 06:15 PM
Hyperlite 30hds
Question on heavy on the equilizer hitch do I need? Looking at the Fastway e2 10,000lbs - 1000lbs tongue or 12,000lbs- 1200lbs max tongue? I really like the looks of this hitch and with a good price
03-15-2016, 11:26 PM
I'm showing a factory tongue weight of 1300 pounds on that unit. You're going to at least want to look into a 1500 pound tongue capacity for that kind of tongue weight. Just making sure ya stay safe is all.
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
03-16-2016, 08:16 AM
I'm planning on using it for reg camping and also a few trips a year with Rzr which weighs 1300lbs which will be all on rear behind axles. Which should take some hitch weight off. Hoping somebody with this same unit could tell me what there running.Does it hurt to go to heavy on equilzer hitch
03-16-2016, 12:31 PM
I have same trailer. I have the 14000, 1400 equalizer hitch. I pull it with a gas 2012 f250 6.2. Pulls great with the equalizer hitch
Xlr hyperlite 30hds couch, party deck, pass thru dinette.
2012 f-250 crew cab 4x4 6.2 v8
03-16-2016, 02:27 PM
I agree with this. I believe the 1400 would suffice. I don't have your same unit but I have a ton of towing behind me from 5ers to flatbeds.
TV: 2005 F250 PSD
03-16-2016, 03:37 PM
How much weight do you haul in your garage? I haven't checked to see if water tank is in front of axle. Do you fill water tank to counter balance load to help with sway? Thanks
03-16-2016, 10:40 PM
Water tank is just in front of axles. I have fuel tank and it's just behind rear axle. I have a 08 kawasaki vulcan nomad, weighs maybe 800 lbs. I did not notice a big difference with or without bike in the garage.
03-17-2016, 09:21 AM
Thanks I ordered 14000lbs equilzer. We haven't used ours yet. It pulled good coming home empty. Just read some post that everything changed with load in back my Rzr weighs 1300lbs. Glad to hear yours pulls good, We moved it yesterday
and the kitchen drawer came open and got caught in the kitchen slide out as it was going out Didn't see it in time Something to definitely watch out for. Just bent the drawer handle over.
03-17-2016, 11:47 AM
I have done the same thing. Now I check and make sure the doors are closed first.
03-17-2016, 03:21 PM
Well I don't feel as bad now I straighten handle out you can't even tell. It knocked that slide off track but I guess that system lined itself back up.
03-17-2016, 05:27 PM
Can you tell me were the bypass for water heater? There usually behind heater there is no access panel The heater is beside generator compartment under bed looked under bed sealed up thanks
03-17-2016, 07:03 PM
Mine just stopped. Another thing I did is. The door under the sink came open going to campground. I allowed daughter to put out slide out where the couch is. The trim piece on the slide pulled loose because the door handle caught it. She luckily stopped before it was ripped completely off. Needless to say we check all doors now! Lots to learn
03-17-2016, 10:16 PM
Same here. Took both handles off the cabinet in the garage and used one to replace the bent one. Now I have a spare. Went to Lowes to replace the 2 from the garage. Found some that are almost an exact match. The only difference is they are about 1/2 inch shorter. Since they are in a different room you can't even tell.
2016 Hyper Lite XLR 30HDS
