Old 03-15-2016, 06:15 PM   #1
Rzrfan's Avatar
Hyperlite 30hds
Question on heavy on the equilizer hitch do I need? Looking at the Fastway e2 10,000lbs - 1000lbs tongue or 12,000lbs- 1200lbs max tongue? I really like the looks of this hitch and with a good price
Name:   ImageUploadedByForest River Forums1458083701.869752.jpg
Rzrfan is offline   Reply With Quote
Old 03-15-2016, 11:26 PM   #2
PolarisGuy's Avatar
I'm showing a factory tongue weight of 1300 pounds on that unit. You're going to at least want to look into a 1500 pound tongue capacity for that kind of tongue weight. Just making sure ya stay safe is all.
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
PolarisGuy is offline   Reply With Quote
Old 03-16-2016, 08:16 AM   #3
Rzrfan's Avatar
I'm planning on using it for reg camping and also a few trips a year with Rzr which weighs 1300lbs which will be all on rear behind axles. Which should take some hitch weight off. Hoping somebody with this same unit could tell me what there running.Does it hurt to go to heavy on equilzer hitch
Old 03-16-2016, 12:31 PM   #4
I have same trailer. I have the 14000, 1400 equalizer hitch. I pull it with a gas 2012 f250 6.2. Pulls great with the equalizer hitch
Xlr hyperlite 30hds couch, party deck, pass thru dinette.
2012 f-250 crew cab 4x4 6.2 v8
dennismo is offline   Reply With Quote
Old 03-16-2016, 02:27 PM   #5
PolarisGuy's Avatar
I agree with this. I believe the 1400 would suffice. I don't have your same unit but I have a ton of towing behind me from 5ers to flatbeds.
TV: 2005 F250 PSD
Old 03-16-2016, 03:37 PM   #6
Rzrfan's Avatar
How much weight do you haul in your garage? I haven't checked to see if water tank is in front of axle. Do you fill water tank to counter balance load to help with sway? Thanks
Old 03-16-2016, 10:40 PM   #7
Water tank is just in front of axles. I have fuel tank and it's just behind rear axle. I have a 08 kawasaki vulcan nomad, weighs maybe 800 lbs. I did not notice a big difference with or without bike in the garage.
Old 03-17-2016, 09:21 AM   #8
Rzrfan's Avatar
Thanks I ordered 14000lbs equilzer. We haven't used ours yet. It pulled good coming home empty. Just read some post that everything changed with load in back my Rzr weighs 1300lbs. Glad to hear yours pulls good, We moved it yesterday
and the kitchen drawer came open and got caught in the kitchen slide out as it was going out Didn't see it in time Something to definitely watch out for. Just bent the drawer handle over.
Old 03-17-2016, 11:47 AM   #9
I have done the same thing. Now I check and make sure the doors are closed first.
Old 03-17-2016, 03:21 PM   #10
Rzrfan's Avatar
Well I don't feel as bad now I straighten handle out you can't even tell. It knocked that slide off track but I guess that system lined itself back up.
