04-15-2017, 11:35 PM
I weighed my trailer today
Took my 413 amp in today to get it weighed on the way home from camping. Truck is a 2011 Silverado 3500 drw lml 4x4 ltz , 3 passengers and 1/2 tank of fuel. I'm guessing my truck weighs 8000 lbs. XLR had no water in any tanks just cloths, some food, a 4 seat rzr xpt. Honda 450, and a kawi 110 dirt bike. Trailer and cargo is 20800 lbs?
04-16-2017, 02:28 PM
Why are you guessing how much your truck weighs... Why didn't you weigh TV without trailer? That way you would know pin weight etc.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
04-16-2017, 02:49 PM
Agree, after going to the scales you shouldn't be guessing about any weights.
Next time drop the front jacks and take the weight off the truck so
you know what's really going on.
Peace!
Dan & Rita D
04-16-2017, 03:29 PM
I guess if I paid for a 1 ton dually and a 21,000 lb 5er, I would just go camping and not bother with scales
04-16-2017, 04:04 PM
No point going to a scale and only weighing half your equation. If you are the kind of person who wants to know your weights, then you need to weigh the truck by itself. From there you can know your pin weight, know exactly how much payload you have, weight on your axles etc...Just guessing is pointless...by the way I am "guessing" your truck with 1/2 tank of fuel and 3 passengers as you describe it, is more than 8000 lbs. My 3/4 ton diesel with only myself in it and a 1/4 tank of fuel weighed in at 7700 # the other day when I took a load to our garbage dump, and that was on a pretty fancy newer scale so I am confident it's accurate....now fill it up with fuel and take it for a ride to your nearest CAT scale, then you will know.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
04-16-2017, 08:03 PM
Thanks guys I was hoping I had the weights of my truck inside the door jam but it just has gvwr. I'll get the truck weighed
04-16-2017, 08:09 PM
The weight you need is of the truck loaded as you will tow, with a full tank of gas and everyone on board; just not the camper.
Then subtract that weight from your combined weight and you will get the weight of your loaded camper.
THEN add the two truck axles unloaded and subtract that from the two truck axles with the trailer aboard and you will find out your actual pin load.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-17-2017, 07:17 AM
This man knows his numbers!!
Peace!
Dan & Rita D
04-17-2017, 07:38 AM
I would go run your truck through the scales without the trailer, (full tank of fuel, all pass. that would be going). From your scale sheet, you look a little light on your steers. If you're worried about the numbers, you can't guess
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
04-17-2017, 08:09 AM
Unless you have three axels your trailer is overloaded with over 16K on them
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
04-17-2017, 09:43 PM
Triple 7k lb axles
04-18-2017, 11:30 AM
Attachment 134855
I have a 2014 Denali 3500 DRW LML 4x4. I just weighed it a few weeks ago - empty, full fuel, and me - 160lbs - it weighs 4820 front, 3540 rear, 8360 gross. I would guess yours is close to that.
I have yet to scale the entire rig, most likely we won't be traveling until this fall.
David and Vicki
19-month-old English Springer Spaniel "Sadie"
2019 Silverado LTZ Duramax
2023 GDRV Reflection 150 226RK
04-18-2017, 11:38 AM
Thank you.
04-19-2017, 07:33 PM
I live in CA. Where is the best place to weigh my truck & trailer?
04-19-2017, 08:24 PM
Any truck stop with a CAT Scale.
