Old 06-29-2012, 10:37 AM   #1
Inoperative Fuel gage
2012 XLR24HFS
fuel gage stays below empty mark. checked fuses wiring etc. Light comes on in gage when fuel pump is running ? Dealer way to busy to lookl at it. Hasn't worked from day 1. Any ideas ?
I have poured 15 galllons gas in tank.
paleale57 is offline   Reply With Quote
Old 06-29-2012, 11:33 AM   #2
Same Fuel Gauge Problem in brand new 2013 XLR
I have the same problem as paleale57 in a brand new 2013 XLR Hyperlite. Fuel Gauge has not worked from day 1. I too checked all the wires and connections that I can get to. I added about 15 gallons as well. Nothing registers on the fuel gauge.
Anyone have any suggestions for us?
BradyB is offline   Reply With Quote
Old 06-29-2012, 11:50 AM   #3
I just talked to a dealer after phoning about 5 and the service guy said some were wired wrong or possibly a bad ground,so I'm going to do some more checking and will advise
Old 06-29-2012, 02:08 PM   #4
I'll do the same...
Thanks Paleale,
Please keep me posted. And I will do the same.
I should have some time to work on this tonight or tomorrow morning. I already checked all the connections and wire-nuts. There is also an inline fuse holder with a 5amp ATC fuse in it, the fuse looks good.
And I can't get to the two wires that go over the tank to the sensor without dropping the tank.
The only thing I can think to do is start switching some of those connections to the back of fuel gauge and see if anything was plugged in incorrectly...
Thanks,
Brady
Old 06-29-2012, 02:40 PM   #5
Originally Posted by BradyB
Thanks Paleale,
Thanks,
Brady
I finally talked to my dealer and was saying there is more than 1 fuse behind the gage but I haven't had time to look yet
Old 06-29-2012, 03:14 PM   #6
Dealer also said there should be a black and a pink wire coming from sending unit black is the ground I guess
Old 06-29-2012, 09:24 PM   #7
After some more resistance/voltage checks I am starting to think it's the gage itself. A wiring diagram would clarify it.
Old 06-29-2012, 09:25 PM   #8
The service dude os pn drugs ther is pnly pne fuse
Old 06-29-2012, 09:26 PM   #9
Only 1 fuse i meant
Old 07-02-2012, 08:34 PM   #10
Okay. Yep, I only see one 5-amp fuse. I haven't put the meter on it yet but I tried switching a few of the connections, nothing yet.
Haven't had a lot of time to mess with it, we lost power in a big storm and have been without power for the last three days. When I get back to it, I'll try testing the gauge itself.
