Old 10-16-2014, 12:41 AM   #11
mark0224's Avatar
Was thinking about doing this but couldn't see the point ,the water source at most of our local State parks dump stations don't have a way to hook up a hose to them. I think I have solved the problem use the low point drain as a water source and hook the tornado up to it then turn the pump on and flush. Just have to hook up a bypass valve to the end of the low point drain to let it drain or flush .
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
black, black tank, black tank flush, tank
