Old 04-05-2015, 08:05 PM   #21
I'm not worried about my solar. Just mentioning I have it. My 6v bank will run the inverter pretty well and Onan 5500 will back it up when low... Good to know on Cotek making both lines. Go Power doesn't have a hardwire with built in transfer switch. Will have to compare pricing between the all in one vs. the two. Thanks for the info...
taken is offline   Reply With Quote
Old 04-05-2015, 08:06 PM   #22
Originally Posted by Blackhat6mike View Post
You might want to reconsider the name brand of the transfer switch as I went through two Go Power switches that were both bad out of the box. Parallax builds a great switch, but it isn't small. Both of the Go Power switches I used buzzed constantly and would not switch. Check the reviews on Amazon.
Thanks for the heads up! Will do...
Old 04-05-2015, 08:06 PM   #23
WestCoastRV'er's Avatar
Originally Posted by mud yapster View Post
I have 2 of the SLR155 and 1 of the SLR125 I like them so far. I think a good charge controller is also key. Your solar array size you will want 5% to 10% charge capacity of your battery bank. So Mine at 435 X .05= 21.75 amps so I'm at about 6%. I have monocystilline panels.
This is the system I'm installing. Only need to add 1 more solar panel and the batteries. So far I please with the results. I now leave my fridge on while in storage so I have cold beer when I go to check on it.
Solar Charger: - COMPLETED
40 AMP MPPT Renogy
Solar Panel: - 1 Panel installed
2 - 250 Watt Renogy
Battery: - To Be Installed Soon
2 - 155AH VmaxTanks AGM
Inverter: - COMPLETED
2000 Watt Xantex PROwatt SW (Pure SineWave)
Transfer Switch: - COMPLETED
PowerMax 30AMP
Inter-connects - COMPLETED
solar panel -> combiner box 8AWG MC4 (6ft)
combiner box -> solar charger 1/0 AWG (10ft)
solar charger -> battery bank 4 AWG (2ft)
inverter -> batteries 4/0 AWG (2ft)
battery inter-connects 4/0 AWG (1ft)
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
inverter, solar, battery
