Old 05-20-2015, 03:52 PM   #21
Covered 6 yellow Linx blocks with alum tread plate to prevent sliding and sinking an bolted them to the jack pads, works great.
ID:	77547   Click image for larger version
Name:	Front Landing jack pads.JPG
ID:	77548   Click image for larger version
Name:	Rear stabilizer pad.JPG
Old 05-20-2015, 07:03 PM   #22
Little grease from the factory that's it
Mickey Moto is offline   Reply With Quote
Old 05-20-2015, 07:04 PM   #23
use a 4x6 under each one
Old 05-20-2015, 07:07 PM   #24
You are right on I am on the 2nd set 1st trip out same problem. I ordered a set of Husky see how they do had good ratings.
Mickey Moto
Old 05-20-2015, 07:14 PM   #25
Factory thanks I'm nuts they said they have never seen that.
Old 05-20-2015, 07:16 PM   #26
Originally Posted by DennisTD View Post
I was out only once so far but had the same problem. I thought maybe I hadn't tightened them enough until I read this thread.
Yea I told the factory they need to look at the jacks they are putting on their is a problem with them.
Old 05-21-2015, 07:19 AM   #27
WolfWhistle's Avatar
Good morning Mickey. Do all 4 jacks do the same thing?
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 05-21-2015, 07:27 AM   #28
vinmaker's Avatar
Originally Posted by Kilday4 View Post
Using a block of some sort under the foot pad of the jack eliminating full extension helps tremendously. I use an 8" thick block of cedar wood. I have found minimizing extension of the screw jacks give more stability.
I agree. Just like the front A frame jack, the longer the extension the more sway and bending of metal you will experience. If you can shorten the lenght of extension up, it will help.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 05-21-2015, 07:28 AM   #29
Another question. You mentioned being able to turn with your fingers. Can you do this after running them down and lifting the trailer 1/2" to 3/4"? I can turn mine with fingers, but only with nearly no pressure on the jack. And i have lubricated mine (unnecessarily) Again, are all 4 doing this?
Hyper Lite was sold
Old 05-21-2015, 07:48 AM   #30
InTheSticks's Avatar
Wolf, mine were and for the most part do the same thing. You crank them down and try and lift the trailer just enough to stabilize it, not pick it up as I dont think you could with these, however when you just let off on the handle it will spin the handle until there is no pressure left on the jack, and will spin fast. The more weight the faster it spins and it might even go an extra turn and than be actually off the ground. I have 4x6 blocks under the jacks so they are not turned that far down.
If I am not mistaken these hold themselves up via friction against the nut on the inside, you dont think that they could already be worn?
InTheSticks.
2022 F150 Lariat, FX4 - Appearance Package
2013 Forest River XLR 27HFS
InTheSticks is offline   Reply With Quote
Old 05-21-2015, 08:34 AM   #31
You can't, or shouldn't, lift the tires off the ground, but they will take some weight. I usually lift it 3/4" or so. You are correct, I think.. Friction against the washers or collars get enough pressure on them to resist turning. That's why no lub should be used.
Hyper Lite was sold
Old 05-23-2015, 04:57 AM   #32
Yes they do
Old 05-23-2015, 06:40 PM   #33
Mine hold well. They aren't designed to lift but to stabilize. ( the method they attached was not the best, self tapping screws, not the best idea) The screw jack snugs right up when the weight is applied. I usually snug them up to approx 1 inch. That usually is enough. I like the blocks that were shown. Nice idea. That would even work better for me because my most recent adventure, the jacks sunk a bit in the sand. I had to re-snug. The jacks have a decal on them showing 8000lbs. My unit is the 29 hfs.
laurajean is offline   Reply With Quote
Old 05-23-2015, 06:59 PM   #34
Yes you can lower the camper with your fingers
Old 05-23-2015, 07:02 PM   #35
You are right InTheSticks mine do the same thing
jacks
