03-29-2016, 06:44 PM
Just brought home a 2017 305VL5
We picked up our new 305 that we ordered the last week of January. It took 6 weeks to come in. And to our surprise its a 2017. I did have a quick question though... Where is the fresh water tank drain? I see a hose tucked up behind the pa el where you fill the tank. Is that it. There is nothing hanging down from the belly except the low point drains.
03-29-2016, 06:54 PM
Not sure why but I am having trouble adding pictures..
03-30-2016, 09:46 AM
I just noticed that when I turned around in the yard that the pin box made contact with my tonneau cover rails. So I will have to hook back up and check to see how much clearance I need. Maybe a good excuse to upgrade to a Mor/ryde pin box that's a little shorter. I use a super glide hitch so the only way to raise that up is with a 3" riser that they sell for it. But the camper sits pretty good so I would rather not do that. I guess this is a common problem with the GM trucks since 2007. Mine is a 2015.5. I would have thought by now the rv manufacturer would have this figured out.
03-30-2016, 12:23 PM
here is a couple pics at the dealer.
03-30-2016, 12:43 PM
here is where the pin box contacted the cover rail. I bent it back up a little already.
2017 XLR Nitro 305VL5
2015.5 GMC 3500 CC SB Z71 6.0
Super Glide 4400
03-31-2016, 07:01 PM
2017 you say.
03-31-2016, 07:19 PM
Yep. I was expecting a 2016 and didn't find out until we got to the paperwork. Even the salesman thought it was a 16. It was one of if not the first 17 the dealer got in.
Super Glide 4400
04-02-2016, 09:50 PM
Try looking behind the axles under the garage. There should be 2 blue hoses. One capped (Fresh Water Drain) uncapped is the overflow.
2014 Forest River
XLR Viper
305V12
04-02-2016, 10:16 PM
Out of Order
Wow...that thing is beautiful and massive! What are you towing it with??
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
04-04-2016, 06:44 PM
I gave a quick look and I saw 1 blue hose sticking down in between the axels. I didn't have time yet to look any harder. If that's it they couldn't have put in a worse spot. My last keystone trailer has a drain valve. This one appears to just have a cover like the low point drains.
Super Glide 4400
04-04-2016, 06:46 PM
I'm using a 2015.5 GMC 3500 with a 6.0 Gas. It pulled it surprising well.
Super Glide 4400
04-05-2016, 06:39 AM
bmallak,
I'm hoping next year I can upgrade to your TV (my current 2004 is starting to show her age...). How has the 6.0 handled any good size hills/grades?
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
04-05-2016, 02:39 PM
Not much yet. I don't expect it to pull like a diesel but the magority of where we go is fairly flat. We will see how it does when we add a couple thousand pounds of cargo. I can tell you this truck is much more stable than my 2007 classic was.
Super Glide 4400
04-05-2016, 04:04 PM
bmallak
I agree the 6.0 will not pull like a diesel but for me it will be a daily driver.
Looking forward to any reports you have with full load in the garage or some steep grades.
Thanks...
04-06-2016, 05:38 PM
Take a look at Laura GMC in Collinsville, Ill. thats where i got my 15.5 with a diesel for over 11k off plus another 750 off from usaa...its worth the trip...hundreds of trucks!
04-06-2016, 08:01 PM
Moto,
Why did you tell me about Laura's GMC. Window shopping is the worst...
04-06-2016, 08:19 PM
but so much fun at the same time! =)
04-12-2016, 09:31 AM
does anyone know if the fresh water tank is over the axels? That is where the drain appears to be. I just assumed it would be in the front half of the trailer. The water pump is up front by the storage area
Super Glide 4400
08-30-2016, 03:04 PM
We have the 2016 305VL5.. Fresh tank drain is between the axles on the slide side.. Non door side..
2016 XLR Nitro 305VL5, 2006 Chevy Duramax 4X4 Crew Cab..:trink39
