Old 03-29-2016, 06:44 PM   #1
bmallak's Avatar
Just brought home a 2017 305VL5
We picked up our new 305 that we ordered the last week of January. It took 6 weeks to come in. And to our surprise its a 2017. I did have a quick question though... Where is the fresh water tank drain? I see a hose tucked up behind the pa el where you fill the tank. Is that it. There is nothing hanging down from the belly except the low point drains.
bmallak is offline   Reply With Quote
Old 03-29-2016, 06:54 PM   #2
bmallak's Avatar
Not sure why but I am having trouble adding pictures..
Old 03-30-2016, 09:46 AM   #3
bmallak's Avatar
I just noticed that when I turned around in the yard that the pin box made contact with my tonneau cover rails. So I will have to hook back up and check to see how much clearance I need. Maybe a good excuse to upgrade to a Mor/ryde pin box that's a little shorter. I use a super glide hitch so the only way to raise that up is with a 3" riser that they sell for it. But the camper sits pretty good so I would rather not do that. I guess this is a common problem with the GM trucks since 2007. Mine is a 2015.5. I would have thought by now the rv manufacturer would have this figured out.
Old 03-30-2016, 12:23 PM   #4
bmallak's Avatar
here is a couple pics at the dealer.
ID:	103323   Click image for larger version
Old 03-30-2016, 12:43 PM   #5
bmallak's Avatar
here is where the pin box contacted the cover rail. I bent it back up a little already.
ID:	103331   Click image for larger version
2017 XLR Nitro 305VL5
2015.5 GMC 3500 CC SB Z71 6.0
Super Glide 4400
Old 03-31-2016, 07:01 PM   #6
mike.t's Avatar
2017 you say.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-31-2016, 07:19 PM   #7
bmallak's Avatar
Yep. I was expecting a 2016 and didn't find out until we got to the paperwork. Even the salesman thought it was a 16. It was one of if not the first 17 the dealer got in.
Super Glide 4400
Old 04-02-2016, 09:50 PM   #8
Plug32's Avatar
Try looking behind the axles under the garage. There should be 2 blue hoses. One capped (Fresh Water Drain) uncapped is the overflow.
2014 Forest River
XLR Viper
305V12
Plug32 is offline   Reply With Quote
Old 04-02-2016, 10:16 PM   #9
Out of Order
Wow...that thing is beautiful and massive! What are you towing it with??
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
todtc318 is offline   Reply With Quote
Old 04-04-2016, 06:44 PM   #10
bmallak's Avatar
I gave a quick look and I saw 1 blue hose sticking down in between the axels. I didn't have time yet to look any harder. If that's it they couldn't have put in a worse spot. My last keystone trailer has a drain valve. This one appears to just have a cover like the low point drains.
Super Glide 4400
