Old 05-26-2013, 08:24 PM   #1
keeps poppin' fuses....
First ever trip in our 27 hfs..... go to put out the electric awning...... pop.... goes the fuse. Install another fuse...... pop.... goes the fuse. By this time, i figured i had too much stuff on. I shut off everything and try to extend awning...... pop.... goes the fuse. Am i doing something wrong? Does it manually extend? So far, this has been the only hiccup. Everything else has been a small learning curve but is working as intended.
Martins5547 is offline   Reply With Quote
Old 05-26-2013, 08:35 PM   #2
VinceU's Avatar
Dometic has a recall on its power awnings made this year, You might be on the list! Recall is for defective motors.
Old 05-27-2013, 09:47 AM   #3
Call your selling dealer and give them the serial number on your electric awning they can determine if its on the list of recalled awnings.
Guest6789 is offline   Reply With Quote
Old 05-27-2013, 09:20 PM   #4
10x
Probably bad motor, they replaced mine on my new unit 2 weeks ago. There is recall on them.
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 05-27-2013, 10:15 PM   #5
I will be contacting my dealer on tuesday morn. I will follow up with how everything turns out. Thank you for your responses.
Old 05-28-2013, 06:39 AM   #6
bubbles's Avatar
I suspect there might be a dead short to ground between the switch and the awning motor. The power wire may have been routed to allow it to rub against something that has penetrated the wire insulation. Just a thought.
Old 05-28-2013, 08:58 PM   #7
10x
Wire would have to touch metal to ground. There is not a lot of metal that leads to ground except in motor. Motor can short to ground.
2014 XLR 27 HFS
