Old 04-05-2015, 11:17 AM   #11
I don't think that's true. I know it isn't in my trailer or any other I've owned. You can run both at once to speed recovery time or both independently but no auto switching between the two.
taken is offline   Reply With Quote
Old 04-05-2015, 11:26 AM   #12
Crockett's Avatar
Originally Posted by taken View Post
Thanks Turbs. Mine are round rocker switches so I'm going with one of these.
I've got two plugged holes in my panel so I'll pop out the filler plug in one of them and add my switch. Then it's as easy as a piece of romex to tie into the output of the breaker.
a length of multistrand TNNN wire better suited than romex I believe...
Crockett is offline   Reply With Quote
Old 04-05-2015, 11:48 AM   #13
It's what's on the shelf...
Old 04-05-2015, 12:15 PM   #14
I would check the power ratings on that switch and compare with the needs of the water heater. They draw some major power and not sure that switch will be up to the task.. but only the actual ratings will tell for sure.
I will be at some point wiring in a regular lighted household switch to make sure it doesn't overload the switch.
Amazon.com: Leviton 1221-PLR 20-Amp, 120 Volt, Toggle Pilot Light, Illuminated On, Req, Neutral Single-Pole AC Quiet Switch, Extra Heavy Duty Grade, Self Grounding, Red: Home Improvement
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 04-05-2015, 12:33 PM   #15
Ford Idaho's Avatar
Yes the water heater does pull some power, an LED switch not so much.
Old 04-05-2015, 12:35 PM   #16
B and B's Avatar
The panel may not be approved for 110vac switches. Can not mix 12vdc and 110vac in the same enclosure.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-05-2015, 12:36 PM   #17
Hot water tank switch
I was told by the dealer that the electric switch for the hot water tank was purposefully placed outside. It seems that if the tank is dry the electric heating element will QUICKLY burn out. Not so if the HWT is run on gas with the tank dry (for a short period any way).
Being outside next to the water supply will supposedly remind you to fill the HWT.
Our previous HILO had both switches inside.
dann & diane Yeager
2109s Mini-Lite
2008 F-150 Ford
dannyeager is offline   Reply With Quote
Old 04-05-2015, 12:59 PM   #18
Tanddhall's Avatar
I am in agreement with most. My 06 Wildwood 22FBS has the rocker style electric switch mounted within the access panel for the water outside the trailer. I sometimes think about remounting it as it currently sits right behind a large line and is very hard to get to.
2006 Wildwood 22FBS
2011 Chevy Silverado 1500
Tanddhall is offline   Reply With Quote
Old 04-05-2015, 01:11 PM   #19
wmtire's Avatar
Originally Posted by Play Harder View Post
When I picked mine up - I was told if electric switch on outside was left on it would automatically switch between gas and electric depending if your plugged in out.. - seems true - I got hot water and not hooked to power switch on - guess I'll have to look to see if there is flame burning when I hook to power to confirm.
Get out and Play Harder��
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015��
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Never seen or heard there being anything automatic on the Suburban water heaters. You may want to research this, as the person telling you it, may not have known better.
You have two separate systems of heating...propane or the electric heating element. Each system has it's own switch.
The propane side has a switch to turn on/off the DSI (Direct Spark Ignitor) which makes the electric generated sparks to ignite the propane. The propane side can be used at any time, provided you have propane and 12 volt DC power.
The electric side has it's own separate switch to turn on/off the electric heating element inside the water heater. You can only use the electric side when plugged into some form of 120 volt AC shore power/generator.
You can have both sides turned on at the same time (remember nothing automatic, it's all manual with the flip of switches)..or use one or the other depending on your needs and availability of 120 volt power.
Problem is, if you leave that electric switch on, and drain the water out of the heater, then you will burn up the electric heating element the next time 120 volt power is connected........as it's not automatic.
This FAQ may help explain it further:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
Old 04-05-2015, 01:41 PM   #20
The LED rocker switch I posted is rated to 16 amps @ 120v so, plenty for the heater. As to mixing 12 and 120 volts in the panel, I could 100 percent care less if it's rated to do so. The panel is no different than a spot on the wall with a 12v switch mounted next to a 120v switch. Means nothing...
electric, hot water, water
