Old 04-05-2015, 08:19 PM   #41
Play Harder's Avatar
Retraction - it does not auto switch from gas to Electric on the hot water - like I was told ----- forgot I had generator running thus hot water lol - checked and confirmed.
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 04-05-2015, 08:24 PM   #42
wmtire's Avatar
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-06-2015, 08:14 AM   #43
No worry my steering wheel is correct. Lol. I can just flip the switch over as the words are printed on the switch it self.
the.wilsons is offline   Reply With Quote
Old 04-08-2015, 08:45 AM   #44
WolfWhistle's Avatar
110V switch outside on the WH on my early 2015 29HFS. If you drain your WH make sure the 110V switch is off, so that when you give it power you don't burn out the element.
I'll try what you suggested, PH. I was under the impression that if gas and electric was both on, they would both provide heat at the same time, bringing about a quick recovery.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-08-2015, 08:54 AM   #45
Herk7769's Avatar
Both are correct. Double check the AC power to the water heater is off before you drain it. Many switch off the WH breaker to make sure.
They are independant systems and can be run DC/GAS, AC only, or, both at the same time (faster water heat recovery when showering).
HAM CALLSIGN - KC3FFW
Old 04-08-2015, 08:55 AM   #46
wmtire's Avatar
That is correct.
You may also want to look at post #41 above.
electric, hot water, water
