Old 05-23-2015, 06:48 PM   #1
Ladder placement
I found a good spot for my 5ft ladder. I dropped the optional fuel tank bracket by 1.5 inches and now I can slide the ladder in the rack that used to be designed to hold the optional fuel tank. ( I simply added 2-1.5 in pressure treated strips and added longer bolts. ) I use the ladder to sweep off the slide out so the roof is clean before departing the camping area.
laurajean is offline   Reply With Quote
Old 06-02-2015, 09:46 AM   #2
Originally Posted by laurajean View Post
I found a good spot for my 5ft ladder. I dropped the optional fuel tank bracket by 1.5 inches and now I can slide the ladder ...( I simply added 2-1.5 in pressure treated strips and added longer bolts. )
Laurajean,
Do you have any pictures for the mod?
Thanks in advance...:thumbup:
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 06-03-2015, 05:44 AM   #3
I have some photos but not sure how to get them on the forum.
Old 06-03-2015, 06:14 AM   #4
Here is a photo of the addition of a 1 and a half inch painted piece of pressure treated to the fuel rack behind the wheels. It allowed enough space to slide in a ladder in the void where the fuel tank would sit.
Old 06-03-2015, 06:16 AM   #5
Simply remove the 6 bolts add the spacer and install longer bolts.
Old 06-03-2015, 06:17 AM   #6
Thank you for sharing the pics...
Old 06-03-2015, 09:16 AM   #7
I was looking at that space as well, I was thinking about storing a couple of 4'-5' planks there for leveling purposes
Berjr1 is offline   Reply With Quote
Old 06-03-2015, 10:15 AM   #8
You could do that, maybe without making the modification.
Old 06-03-2015, 02:24 PM   #9
that what i was thinking. right now I've just been putting them in the back of my truck will try it to see if it is a pain to get in and out or not
