Old 06-30-2011, 06:45 AM   #11
Hi , My window also had a small gap between the glass and where it glues to the internal frame. I ran a small bead of silicon sealer around the window where they are glued and the leak stopped.The opening for my window was cut quite large and care must be taken when installing the window into the opening so the gasket will fill the gap around the entire perimeter.
Hwing95 is offline   Reply With Quote
