Arrived at the camp ground this weekend and started setting up. The wife called out that she needed my help inside. Come to find out a quart plastic bottle of soda in the lower cabinet had pushed the door open and when the wife opened the slide it caught the door handle.
The slide trim pulled loose and the cabinet door cracked along the side with the handle.
. It took some doing but I was able to get the plastic bottle back up close the door and open the slide. I fixed the slide trim, but the door will require some wood work.
Lesson learned check the clearence for slide outside and make sure cabinet doors are closed inside.
Fishing was good and beer was cold, good weekend
