Old 08-23-2015, 01:49 AM   #1
LED light question
Anyone know a quick fix on these led lights without going back to dealer? They was working fine. If the picture dosnt load. The lights I'm referring to are above the door on the rear of camper. Only part of the light is lighting up.
Xlr hyperlite 30hds couch, party deck, pass thru dinette.
2012 f-250 crew cab 4x4 6.2 v8
dennismo is offline   Reply With Quote
Old 08-23-2015, 02:02 AM   #2
Hopefully picture post
Old 08-23-2015, 11:44 AM   #3
Hedrock's Avatar
I had the same issue with 2 of mine. I had a bad one over the ramp and one over the fuel station. The dealer ordered 2 lights to replace the bad ones. When I took them in to repair the tech didn't check the lights to see which were bad they just replaced the 2 over the ramp. I was very frustrated and decided instead of dragging it back to them that I would do them myself. I looked on eBay and found exact replacement lights and bought 2. I figured I might need a spare someday.
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
2016 Hyper Lite XLR 30HDS
Hedrock is offline   Reply With Quote
Old 08-23-2015, 12:51 PM   #4
Thanks! I have to go back to dealer also. When I hook up a hose to fill fresh water tank the water just trickles in and takes forever to fill tank. How long does it take you to fill yours?
Old 08-23-2015, 03:00 PM   #5
LED light question
We had some LED marker lights that went bad. Dealer sent me new ones and a return label for the old ones. Too about 10 minutes to replace them. I HATE having to go back to a dealer.
2014 XLR27HFS
2006 Ford F450 Dually Diesel
breezyhillfarm is offline   Reply With Quote
Old 08-23-2015, 04:03 PM   #6
Hedrock's Avatar
Had the same problem with mine. It was fixed before I picked it up. I have only used city water since.
Old 08-23-2015, 04:23 PM   #7
What exactly was your problem? I know it's not the valve you turn from city to fill tank. I know because I swapped the lines in the pantry and still had the filling problem. Anything I can fix?
Old 08-25-2015, 02:01 PM   #8
3 out of 4 of my LEDs have failed as well, and they are a PITA to replace as they are siliconed on and hard-wired. I'm looking for a good quality replacement set and I'll just replace them all. I don't want replacements that will just fail again. I've found they work about 30 minutes before they fail.
DennisTD is offline   Reply With Quote
led, light
