Old 08-12-2015, 04:49 PM   #21
Originally Posted by bob caldwell View Post
Depends on where one's camping.....
Fair enough. Well, when your neighbor is five feet away.
2014 XLR27HFS
2006 Ford F450 Dually Diesel
breezyhillfarm is offline   Reply With Quote
Old 08-12-2015, 04:50 PM   #22
Left Coast
X2
Old 08-12-2015, 06:16 PM   #23
oldgold's Avatar
Originally Posted by Sturgie View Post
Anyone have a link as to where I can get these led lights for my 27HFS?
I've been getting stuff from HitLights. They have very good customer service and very knowledgeable people up there.
www.hitlights.com
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 08-16-2015, 07:17 PM   #24
oldgold's Avatar
Thanks to klarowe for some good ideas!!!
I ended up getting RGB lights and replaced the bright white lights. I found an inline RGB controller with remote that worked really well, it even almost got in the track it was so small. I cut the wire at the awning track and installed the controller. Then waterproofed with shrink electrical tubing and wrapped with electrical tape. I cut down the wire track clip and reinstalled to help hold the wires in place on either side of the connection. Now it work off the switch inside still and can then be adjusted by remote. Another good thing is the remote that came with it works on RF. seems to work within about 30ft or so.
Ended up working out really well!
Old 08-16-2015, 08:06 PM   #25
Very nice.
2014 XLR27HFS
Old 08-16-2015, 08:49 PM   #26
PhoneDude 8289's Avatar
Originally Posted by Flybob View Post
64 Watts of LEDs . Your going to need sun glasses.
Or a welders helmet
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 08-16-2015, 08:51 PM   #27
oldgold's Avatar
Originally Posted by PhoneDude 8289 View Post
Or a welders helmet
It's actually not as bright as the white lights that came from the factory. Plus the remote installed has a dimmer.
Old 08-17-2015, 07:43 AM   #28
Taranwanderer's Avatar
OG--which kit did you wind up getting from hitlights? Looking at your remote, it only looks like they have short sections of RGB lights with that one. Did you have to buy a kit and then also buy a longer RGB strip?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-17-2015, 07:49 AM   #29
oldgold's Avatar
I bought the Luma 10 series RGB waterproof strip and the controller from the pictures. I gave up infinite colors, but made for a hell of a lot easier install. I've seen on here where people were having to take their controllers down every trip or having to do a whole bunch of wiring. I'm lazy by nature and I chose the path of least resistance. I cut into the power right at the LED strip and installed the controller. Made it as waterproof as possible. If it rusts out, all I need is another $14 controller.
Old 08-17-2015, 06:49 PM   #30
So it was this controller:
Luma10 Series - R108 Multicolor LED Controller - With RF Remote Control
And this strip?:
Dreaming Style RGB Kit
The only reason I ask is that FR couldn't seem to properly affix my LED strip to the camper body, and even after the dealer "fixed" it, it's still coming loose in places, and I see me replacing it someday. Someday soon.
Old 08-17-2015, 06:57 PM   #31
oldgold's Avatar
Correct on the controller.
These were the strips.. I chose high intensity & waterproof.
http://www.hitlights.com/luma10tm-se...trips-smd-5352
I think you posted the kit which comes with a power supply. You shouldn't need that unless you plan on plugging into a 110 outlet. You should be able to cut wire at awning feeding existing LED. Splice on the RGB Controller and then plug in the 4pin on the LED.
Old 08-17-2015, 07:01 PM   #32
oldgold's Avatar
Our XLR has a track right under the awning fabric that is the correct size to pop in the LED strip. I didn't have to glue it down. The adhesive on the strips is so so at best. I would bet all of them would come down after a year or two.
Old 08-17-2015, 07:05 PM   #33
Thanks for the info. I didn't see a power supply on that controller kit, just the remote and the inline controller. Plus it was $14.99, and that's what you said you paid for it....
I'm gonna have to lobby the DW for RGB lights...not sure if she'll go for it.
Old 08-17-2015, 07:08 PM   #34
oldgold's Avatar
The light strip link you posted said it came with power.
awning, led, light
