Old 08-17-2015, 06:57 PM   #31
oldgold's Avatar
Correct on the controller.
These were the strips.. I chose high intensity & waterproof.
http://www.hitlights.com/luma10tm-se...trips-smd-5352
I think you posted the kit which comes with a power supply. You shouldn't need that unless you plan on plugging into a 110 outlet. You should be able to cut wire at awning feeding existing LED. Splice on the RGB Controller and then plug in the 4pin on the LED.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 08-17-2015, 07:01 PM   #32
oldgold's Avatar
Our XLR has a track right under the awning fabric that is the correct size to pop in the LED strip. I didn't have to glue it down. The adhesive on the strips is so so at best. I would bet all of them would come down after a year or two.
Old 08-17-2015, 07:05 PM   #33
Taranwanderer's Avatar
Thanks for the info. I didn't see a power supply on that controller kit, just the remote and the inline controller. Plus it was $14.99, and that's what you said you paid for it....
I'm gonna have to lobby the DW for RGB lights...not sure if she'll go for it.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-17-2015, 07:08 PM   #34
oldgold's Avatar
The light strip link you posted said it came with power.
awning, led, light
