Old 03-31-2016, 11:16 PM   #11
northstar1960's Avatar
Originally Posted by breezyhillfarm View Post
I had three go out. Called my dealer and the parts guy sent me some to replace them. Also sent a paid postage sticker so I could send the old ones back and they can get credited. 15 minutes to replace. No muss, no fuss, no angst.
Decided to do the same . sent all the info to Couches and it should be taken care of , need to wait for the mail either way and i shouldn't have to pay 18.00 plus shipping to order on my own when the warranty should cover it
northstar1960 is offline   Reply With Quote
Old 03-31-2016, 11:19 PM   #12
Originally Posted by WolfWhistle View Post
Lamps not covered on the extended warranty. I'd just buy them online - Amazon/ebay
They should be covered ,as has been discussed on a few other threads on this forum , if not i have issue , material and workmanship. IMO marker light are material being used , and not installed so as to prevent water intrusion workmanship .
Old 04-01-2016, 03:27 PM   #13
Good.
breezyhillfarm is offline   Reply With Quote
Old 04-10-2016, 05:00 PM   #14
Well Couches came through along with FR and sent me the two new front LED markers lights under the extended warranty . So now it's just install and seal ! Then i think going through all the other lights and sealing from water is in order
Old 04-10-2016, 06:25 PM   #15
Great. Glad it worked out.
Old 04-11-2016, 09:55 AM   #16
The Big Toe's Avatar
The employees get bonused on production numbers and back-charged (minimally) on warranty work.
I've seen lines like those in other manufacturing places. They won't slow down and do the work properly until they're MADE to slow down and do the work properly. QC can only catch so much.
It's not like you're taking away their kids' Christmas toys when you file a warranty claim. It actually helps the consumer -- Or the next one, anyway.
I've seen the lenses put on upside-down on some trailer lights. The bottom side has a tiny little drain cut-out so moisture can escape.
It matters.
The Big Toe is offline   Reply With Quote
Old 04-11-2016, 04:13 PM   #17
the lights should be sealed completely , the LED's are great lights but don't work well in wet places .
led, light
