02-25-2015, 07:48 PM
Lifting a 27HFS
Well, I'm not really finding anything as far as lift shackles go. Mainly guys are doing what I did to my old camper, just setting the springs on top of the axle instead of them being under it. Has anyone done it to a 27HFS?
02-25-2015, 09:21 PM
I have a work & play 30wrs and am needing to raise it. Mine has lippert axles. I called forest river about it and they would not authorize do anything, however, they gave me the number for lippert. I must say the man at lippert was excellent. Per lippert you can't just move the axle under the spring as the alignment will be exactly backward. My 30 wrs has 2 holes in the spring hangers and they were already reinforced from the factory. Per lippert we are going to lower my springs to the bottom mounting holes for the springs as well as the equalizer and this will give me an extra inch of clearance above the axle. As soon as the snow and ice give me a break I will be doing this.
02-25-2015, 09:29 PM
I guess I'll have to figure out what brand my axles are and go from there! I'd like mine to be 4-6 inches high than it is, there's too much crap to get torn out of the bottom if I don't.
02-25-2015, 09:35 PM
If your needing to go that high I would say you need a good fab welder and some frame material to raise the mounts on new framework... Like shackeling up a GTO.
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
02-25-2015, 09:37 PM
That's what I'm thinking
02-25-2015, 09:39 PM
Just make sure your welder knows what he's doing or your in for a real surprise if it goes south .... Don't go cheaper when you need it to hold JMHO
02-25-2015, 09:45 PM
How old is your camper. When we started with mine they told me to look for the tags on the axles and my trailer is a year and a half old and the tags look brand new. They tell who built them and their rating. the people I dealt with at lippert were outstanding. I would see if it has their axles and then call them and explain the situation. When I explained what was wrong they were extremely helpful and you might get them to give you a procedure to raise it that they approve of.
02-25-2015, 09:48 PM
Scott, mine's a 2014 model.
02-25-2015, 11:09 PM
Most likely Dexter
02-25-2015, 11:30 PM
Can I ask the obvious question here: why do you need to lift your TH? It's going to introduce a whole host of other issues: entry ramp is going to be steeper with more break over angle, you'll max out the jacks quicker, trailer will be harder to stabilize when parked due to being higher, and that first step in and out is gonna be a doozy!
I'm a Jeep guy from way back, and I know when you start lifting things, it's becomes a whole litany of stuff you need to address (ie, throw more money at) over and above just swapping/flipping/replacing springs. So I guess I'm just asking why you want to do this to yourself.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
02-25-2015, 11:57 PM
Well, we camp off road a lot on big ranches out west. I don't want to rip any plumbing off of the bottom! I did it to my last travel trailer and it worked great!! I'm hoping to do it again with this new TH.
02-26-2015, 01:39 AM
Ive done a lot of these. You need to weld fresh spring perches to the top of the axle tube, and place them under the spring. You get 4.5 inches lift with a 2 3/8" axle and 6" with a 3" tube. If you have shocks , you need to modify accordingly. You will need a new step or one of those beefy platform steps to accomodate.
02-26-2015, 10:05 AM
X2 taranwander
My 29HFS is already flipped...Springs on top. I was thinking of dropping mine, for about 15 seconds.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
02-26-2015, 10:23 AM
Excellent......then I'm doing it!! You're pretty sharp for a Msgt!!
02-26-2015, 10:43 AM
Wouldn't it be better just to put some sort of shield underneath to protect the guts?
02-26-2015, 11:27 AM
No, you give me too much credit... it came that way So, your 27 has springs below the axles? If I needed more clearance, I would not hesitate to either flip it or add "lifting" blocks and longer "U" bolts. but like taranwanderer mentioned, the steeper ram would be an issue for me. With, dirt bikes and 4 wheelers not so much.
Hyper Lite was sold
