Old 10-28-2015, 06:09 PM   #11
No problem... Glad I could help...
Karl4Cat is offline   Reply With Quote
Old 10-30-2015, 08:12 AM   #12
Just place the order with Lippert for the new level up control module with wireless capabilites. Karl4Cat you offered up some instructions on install to save me some aggregation. Look forward for you help once again.
mje000 is offline   Reply With Quote
Old 10-30-2015, 08:22 AM   #13
Do you already have the remote or are you ordering that as well? The process to pair the remote to the wireless level up module is hazy as I did it in the spring. However, Lippert tech line talked me through it in about 3 minutes after I had swapped it in. They will do the same for you. A tip I can offer is to make sure the trailer is level before you swap in the new module. When you swap in the module and power up the wired controller you will get an error and a message telling you to press enter to acknowledge. Once you do that the system will go into it's zero point calibration. This is why the trailer should be leveled before you swap the module. The trailer's level position is stored in the module and when you replace it with the new one it won't know what level is. Having the trailer already level before swapping saves you having to manually level the trailer before setting zero point. So, since your already level, hit enter again to begin zero point calibration. Within about 10 seconds or so level position will be stored in the new module. At this point you can call Lippert and get the process of pairing the remote to the control module. It involves pressing the home button 5 times to enter the config menu. There are two more steps and you'll be done.
Old 10-30-2015, 08:33 AM   #14
Already have the remote and setup to work slides and awnings currently
Old 10-30-2015, 08:37 AM   #15
Read above. I edited to give you a couple of tips.
Old 10-30-2015, 08:40 AM   #16
Great thanks
Old 10-30-2015, 08:50 AM   #17
Make sure you tell Lippert that you want the process to pair the remote to the level up module and NOT the Linc receiver that's been in your trailer all along. The tech I talked to at Lippert first had me re-pair my remote to the Linc receiver which is completely unnecessary. It pairs to the level up module independent of the Linc receiver.
Old 10-30-2015, 08:56 AM   #18
This are the two screens you will end up with once your paired.
Old 10-30-2015, 09:03 AM   #19
R3Jones's Avatar
Officially jealous 😉
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 10-30-2015, 09:26 AM   #20
I'll give it a try once it arrives
