Old 06-26-2016, 09:38 PM   #1
egladden's Avatar
Lippert leveling system
Has anyone else experienced this?
This morning I was getting my 2016 XLR 425 ready to leave home and when I put the leveling system controller in manual mode and hit retract and hit the rear button my slides started coming out instead of the jacks on the rear going up. Would that be an electrical issue or a hydraulic problem I am confused.
egladden is offline   Reply With Quote
Old 06-29-2016, 02:25 PM   #2
Haven't heard of the problem, but I would look for a bad ground somewhere. I know when messing with old cars and boat trailers, when you have weird stuff happening it usually means a bad ground.
the.wilsons is offline   Reply With Quote
Old 07-18-2016, 10:19 AM   #3
Not to experienced with the leveling system but I would guess there is something crossed whether it be hydraulic lines or control wiring something is not hooked up correctly?
VICSXLR is offline   Reply With Quote
Old 07-18-2016, 05:36 PM   #4
egladden's Avatar
This is something that just started and hasn't happened before.
Thanks for replying
Old 07-18-2016, 09:24 PM   #5
One time when putting my front jacks down in manual mode, the bedroom slide started coming out once the jacks hit the ground. I ran it back in and it hasn't happened since.
I think someone said the hydraulics run off the same and maybe a valve stuck open or something like that.
As I said, it hasn't happened since and that was 3-4 trips ago.
2015 F350 6.7L Lariat CC LB
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 08-17-2016, 07:51 PM   #6
They do run of the same system, I tried to level and wife put slides out at the same time. Levellers won and the slides stopped.
Ian Stewart is offline   Reply With Quote
leveling
