Old 08-20-2016, 05:52 PM   #11
change doors materials
Originally Posted by andy29847 View Post
Three doors on my toyhauler too. Lippert has paid for everything. The bad thing is all the time my toyhauler has spent in the shop. FWIW, my doors were failing on the hinge line.
My story: Three Years with A Thunderbolt
why they don't use all Aluminium for the doors?
jeffowen is offline   Reply With Quote
Old 08-22-2016, 02:15 PM   #12
That appears to look like a seam in the anti slip coating to me and not a crack
Speaking of the anti slip coating which by the way is slippery when it gets wet. I slipped down ours the other day taking a bike out because it was wet and unfortunately the foot peg punched a hole in the ramp. it did not go through to the other side but there is a hole int he plywood. Wondering has anyone repaired a hole in the ramp before? My hole is about the size of a silver dollar. I was thinking about some spray foam to fill the void a bit and then overlaying some more anti slip on top of it
Berjr1 is offline   Reply With Quote
Old 08-22-2016, 04:51 PM   #13
northstar1960's Avatar
get some horse hair fiberglass to fill and sand to flush then recover . the spray foam will not hold up . or some other heavy duty epoxy
northstar1960 is online now   Reply With Quote
Old 08-23-2016, 10:44 AM   #14
Good idea I could fill it with some epoxy. thanks
Old 08-23-2016, 04:02 PM   #15
Harleyrider
I have had three ramp doors put on put on our XLR also. Not fond of Lippert ramp doors but seem to be the only supplier.
harleyrider03 is online now   Reply With Quote
Old 09-19-2016, 08:15 PM   #16
Send a message via AIM to Curtster122 Send a message via MSN to Curtster122
My ramp door is doing the same thing. Actually it's more like the hinges are breaking through the door. I am very concerned about loading and unloading my motorcycle in the event that the door brakes off completely.
Curtster122 is offline   Reply With Quote
Old 09-20-2016, 08:27 AM   #17
mx411's Avatar
Name:	ImageUploadedByForest River Forums1474374344.164868.jpg
ID:	120771Click image for larger version
Name:	ImageUploadedByForest River Forums1474374356.664551.jpg
Yep. Same here. Just sent pic to the dealer I bought it from. Heaviest bike I load is 125#. See what happens.
2016 29HFS Hyper Lite
2016 Ram 2500 CTD
mx411 is offline   Reply With Quote
Old 09-20-2016, 07:24 PM   #18
I'll be keeping an eye on mine . load the bike [use the ramp] about 5 times a year so far so good
Old 09-21-2016, 04:00 PM   #19
WolfWhistle's Avatar
why wouldn't a rubber mat / floor glued to Styrofoam with 3/16" plywood and 1/16" fiberglass on the other side not hold up. Why would 100 psi rolling up it cause failure? Lippert should replace every darn ramp built like this with something that will hold up. The ramp should have 1/4" aluminum plate under the rubber mat / surface.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
WolfWhistle is online now   Reply With Quote
Old 09-21-2016, 04:18 PM   #20
chpence1's Avatar
Mine is partly hollow around the perimeter. Most notably where the hinges attach.
Pictures included.
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
door, factory, warranty
