Old 07-01-2018, 10:22 PM   #1
Loading and unloading garage
I’m new to toy haulers. I have a 29 ft XLR. Can I load and unload the garage while unhitched from my truck if I’ve got the levelers set? I know you shouldn’t on a regular flatbed trailer but, wasn’t sure with the travel trailer.
Akfordguy is offline   Reply With Quote
Old 07-02-2018, 05:43 AM   #2
What are you loading? Bicycles? ATVs? UTVs?
KFX450RXC is offline   Reply With Quote
Old 07-02-2018, 07:03 AM   #3
I only load & unload my motorcycle when hooked up to the truck. No stabilizers are down.
Sent from my SM-G955U using Forest River Forums mobile app
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 07-02-2018, 10:14 AM   #4
ATVs and UTVs
Old 07-02-2018, 10:20 AM   #5
Always Learning
Yes, as long as the stabilizers are down, you can load/unload.
Old 07-02-2018, 10:29 AM   #6
Oaklevel's Avatar
X2 We load and unload our golf car almost never with the trailer hitched to the truck. Granted ours was a fifth wheel. most of the time with the stabilizers down.
If you think about it the garage is in the back (normally behind the axles) the tongue weight has to remain heavier than the back end even when loading as the weight that you are adding can't lift the front end or you would not be able to control it towing it. A car hauler is different as you are bringing the weight starting in the back moving it to the front or tongue end.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-02-2018, 10:39 AM   #7
Old 07-02-2018, 11:10 AM   #8
ben31's Avatar
I thought you can only load or unload if you are in the white zone. Oops, I think that is from a song. Nevermind!
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 07-02-2018, 01:08 PM   #9
I have unloaded while unhooked and level. However for loading my Electra Glide, I've found it better to be hooked up and the trailer jack as high as I can get it to avoid the dreaded kickstand rub.
Bnrc73 is offline   Reply With Quote
Old 07-02-2018, 01:46 PM   #10
A32Deuce's Avatar
Airplane!
A32Deuce is offline   Reply With Quote
Old 07-02-2018, 03:45 PM   #11
Yes you can . this way you can raise the front anmd have a lower load angle . best to put the stabilizers down but not necessary at all . have loaded my 900+ lbs Vulcan many times with out stabilizers down the unit doesn't even know your loading
MR.M is offline   Reply With Quote
Old 07-07-2018, 02:22 PM   #12
49Willys's Avatar
I've loaded my RZR XP1000 (1500lbs) unhitched , wheels are chocked I just go slow and easy, I do keep the water tank full when I travel.
49Willys is offline   Reply With Quote
Old 07-07-2018, 02:58 PM   #13
I've loaded my RZR and my Harley without being hitched and no stabilizers down. Won't hurt a thing IMO.
As stated go slow
Triple J is offline   Reply With Quote
