Old 06-09-2014, 06:02 PM   #11
Kilday4's Avatar
Ace,
We have 27 HFS with the extreme package and onan gen. Towing with our (garage queen) 06' F150 5.4 HD 3.55 gear that has only 55k miles. With 4 dirtbikes in the garage and all our camping gear I am right at my trucks maximum capacity. Now I wouldn't want to drive coast to coast with it but for shorter trips 200-300 miles it works for us. The key is slower speeds, good brake controller, and a properly setup WDH. I also added 2k lb. helper springs just to be safe on the hitch weight. Don't get me wrong, ultimately someday I would like a 3/4 diesel but there is a lot of life left in my half ton garage queen. By the way, we love our XLR.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 06-10-2014, 06:43 PM   #12
I pulled the 27 HFS with my 06 F150 5.4 3.55 rear end for about 9 months. Just within specs but after 9 months starting getting rear end shudder when turning. First when towing but later when empty and not towing. Had fluids/filter changed in both rear end and transmission but shudder did not go away. Traded for a 2500 HD Chevy 6.0 gasser. No comparison on towing. Heavier duty, no matter what brand, is the requirement. Don't pull the 27 HFS with a 1/2 ton. Not a good fit.
2017 Salem Hemisphere 326RL
2009 Chevy Silveraldo 2500
meandmylabs is offline   Reply With Quote
Old 06-10-2014, 08:48 PM   #13
We are towing our 27HFS with a Chevy Avalanche which is rated for 8000lbs with the 2 Harley's in the back. With load equalizing bars and sway bar we are not seeing any real difficulties towing as of yet. Only difficulties we've had was trying to figure out the best way to tie both bikes down...
New England Sports Nuts is offline   Reply With Quote
Old 06-11-2014, 05:18 AM   #14
Well maybe my differential problem was isolated and even though my F150 seemed ok when towing, I realized after pulling the same trailer with same hitch, setup and load that the heavier duty tow vehicle really makes a huge difference.
Old 06-11-2014, 07:36 AM   #15
Kilday4's Avatar
I have had same shudder since 10k miles. Long before I ever started towing. Changed gear oil in rear end with no results. Have been told pinion gear needs shimmed but have never done it. Problem has never gotten worse. Only does it basically when turning from a dead stop. I do agree that this is not the most ideal TV for this trailer but I like the fact it's paid for. And, our trips are in the 200-300 mile range at the longest.
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Old 06-16-2014, 10:01 AM   #16
I have a 24HFS and a 2013 Dodge 1500 and no problems towing 2 Harleys in the back.
As someone else said the key is having a proper WDH and sway system
SIBELL is offline   Reply With Quote
Old 06-17-2014, 12:34 AM   #17
Sturgie's Avatar
Meandmylabs was using, dare I say, a truck not equipped to tow a 27HFS; and he knew it. His truck had a 3 speed plus overdrive, 3.55 rear end, and a 300hp motor. A truck with that tyranny has to be left in a manual 3rd and is probably limited to 60mph, maybe a little more, due to rpm's. All of the newer 1/2 ton trucks have a more suitable trannys (5 or more speeds), more power, and better rear ends, if selected. I have 2wd 5.7 Tundra tht has been towing my 27hfs since '12. My longest trip however, is less than 400m one way. I am properly set with everything, tow at 65 and get 8-9mpg. The tundra does the job just fine for now. I mean, who doesn't want a set it and forget 3/4 ton diesel, right? If you do go to a newer half ton, make sure you get the big motor and it's equipped for towing: ex. tow mirrors, tranny cooler, towing rear end, etc. But, it's all just my personal experiences and opinion I'm sharing.
If your stuck with your dodge, then you have to go for the 24. The 27 is way better for your needs, though.
Sturgie is offline   Reply With Quote
Old 06-17-2014, 06:47 AM   #18
Some interesting assumptions about my old truck. Yes it did have the 4 speed transmission but was the heavy duty towing package and was within specs pulling the 27HFS in 3rd gear.
My point, however is that there are a lot more things different by pulling with a heavy duty truck than just power. Stability with a heavy duty truck is a HUGE difference. A TH with a rear garage causes a large amount of weight to be placed toward the rear of the trailer and can really cause havoc with your setup.
I understand that many purchase the 1/2 ton trucks because they are also the daily driver and are a little less expensive to operate but I could really notice the difference with a heavier duty truck.
The OP asked for our opinions and I have shared mine.
Old 06-17-2014, 06:49 AM   #19
Sturgie's Avatar
Well said.
Old 06-17-2014, 07:55 AM   #20
I tow my 27HFS with a '01 ford expedition 5.4L 3.73 gears, 205k miles. yellow sticker on the camper is 6700 lbs. by the time I get the golf cart, kids bikes, firewood, gear, and other items, I think that I am reaching the ceiling of around 8500 lbs when loaded for a trip.
Towed the camper from Ohio back to Maryland a year and a half ago and have gone on several trips since. Although the expedition tows OK, you always want something that is a little more spec oriented.
Braking can get a little squirrely at times so you will have to allow for a little more stopping distance.
I believe that the expedition is on the teetering edge of going over the spec; that is why I am in the market for a 3/4-1 ton diesel to get that extra added comfort for the family.
As the expedition sits now, during towing in the summer months, I cannot run the a/c which is just miserable on long drives. I have 1 more trip to get thru during 4th of July and then the expedition will be retiring from my vehicle arsenal.
Martins5547 is offline   Reply With Quote
