Old 04-05-2016, 07:30 AM   #11
John513
JohnRiordan's Avatar
I also spray the gaskets around the slide and the rails with dry silicone lube a couple times a year to prolong the life of the gaskets.
JohnRiordan is offline   Reply With Quote
Old 04-05-2016, 07:33 AM   #12
John513
You can also use wd-40 on the gaskets.
Old 04-05-2016, 10:20 AM   #13
True, but WD-40 smells.
breezyhillfarm is offline   Reply With Quote
Old 04-13-2016, 02:24 PM   #14
The Big Toe's Avatar
Maybe some PAM or an unscented Cooking Spray.
Maybe a better idea would be some Mineral Oil or even some vegetable oil although the cooking oils could attract critters.
Or not.
The Mineral Oil is generally a petroleum product. Very weak as a rule. Some of it is food grade like they use on cutting boards.
Maybe some bees wax or even furniture wax. Paraffin?
Lots of non-chemical, non-smelly choices out there
The Big Toe is offline   Reply With Quote
cat, slide
