Originally Posted by youroo
The "MAXXFAN and MAXXFAN PLUS" have built in mounting Tabs for Install of the "FANMATE" vent cover! The "MAXXFAN Deluxe" Needs No cover,it is built in! Youroo!!
The problem with those built in tabs, if your referring to the ones molded into the plastic mounting flange, is they require you to push the cover down into the sealant around the vent. Our covers that came from the factory were mashed into the wet sealant by Rockwood when they built the rig so they could use those built in tabs. Both vents developed leaks in a couple months where the covers were pushed into that sealant.
I had to re install them using Maxxairs metal L brackets which raise the cover above the sealant. I believe they call them the zero leak
mounting kit.
