Old 02-08-2016, 08:20 PM   #11
TURBS's Avatar
Glad to hear it was 120v!
Now did the microwave short out causing the burnt wires or was it a bad connection that burnt the wires?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-08-2016, 09:05 PM   #12
WE checked the line build sheet as beachcamper asked in his reply and the model # was listed BUT the serial # was never listed by FR. As per burnt wires, their is no way to tell. The inside of the microwave was all shot. Things shorted, burnt and blown.
Who knows! The the cord or plug showed no signs of arcing or burnt.
hdmtnrider is offline   Reply With Quote
Old 02-09-2016, 06:50 AM   #13
Did he use the appliance last year? If he has never used it or set the clock ask for the hi pot test from the factory. I had a radio with similar problems.
dberg is offline   Reply With Quote
Old 02-13-2016, 09:02 PM   #14
Taranwanderer's Avatar
Not that this is your problem, since you verified the 120 vs 240 question, but the easiest way to see if your converter is working is to take a voltmeter reading off your battery with the shore power disconnected, it'll read around 12.6v or so, depending on the battery's condition. Then hook up the shore power and test it again, it should read 13.3v or even higher (14+) if your converter is in "bulk" mode.
Good luck!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 02-13-2016, 09:49 PM   #15
SeaDog's Avatar
My TT came with a magic chef residential unit and when I went to heat a bowl of soup it started vibrating and making all kinds of noise and smelled of burning insulation. these units are not high end microwaves. I marked the case so I won't get the same unit back. Mine had no serial number just model number
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
