Old 06-12-2014, 08:30 AM   #1
microwave issue !!
Have xlr 395 amp and went to power up unit and microwave got power and 0,s were flashing but lite was on under unit and there was no button controls for front panel. I tried power and lite and start and nothing. I also tried turning off at breaker and shutting down power but same thing. Has anyone had this issue ? I am thinking a board issue maybe ??
l395scot is offline   Reply With Quote
Old 06-12-2014, 09:31 AM   #2
KyDan's Avatar
Microwave make and model might help but since you've powered down and
back up and have same issue- it sounds like a defective MW.
You should probably seek warranty work from dealer but you might be able
to get a warranty replacement from the microwave maker if you can change it
Good luck!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 06-12-2014, 10:11 AM   #3
Loefflerh's Avatar
In the cabinet to the left of the microwave you find a round white cover (on the side facing the microwave) . Unscrew it and then you see a typical 110v outlet where the microwave is plugged in.
I would suggest use an extension cord from your house, plug the microwave in that and see whether it is working....if not its definitely the microwave itself...
Loefflerh is offline   Reply With Quote
Old 06-15-2014, 09:44 AM   #4
Kilday4's Avatar
You might have to set the clock before having full fictions. Our microwave at home is like that. Good luck
Mike & Kim Kilday
11' F250 6.7 SD
15' XLR 27HFS EP
Kilday4 is offline   Reply With Quote
Old 06-16-2014, 10:20 AM   #5
thanks kilday4 , i called up rv dealer and they said they just remove and get fixed. Sounds like a panel board so just having small aplliance people fix right in trailer . I did try your suggestion and unplugging and such but no funstions on panel at all
