Old 03-15-2015, 07:43 AM   #11
I have the Condor that I use for my Softail. Holds the bike firmly without straps if needed; easily removable. Great quality.
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 03-15-2015, 08:18 AM   #12
Mark S's Avatar
I use the Condor on my Road Glide Ulta, over 800 lbs dry. It's very secure and works great. It's kind of pricy but probably the best out there. I did not bolt it in on this camper and use four straps. I never worry about it.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 03-15-2015, 06:12 PM   #13
northstar1960's Avatar
Originally Posted by dennismo View Post
I bought one; but it won't work with my bike. I Have A 08 KAWASAKI vulcan nomad. Front tire is to big. Other than that it looks like a great product.
What is your tire to fat ? seems you have a 16" rim this harbor freight model should handle it .
northstar1960 is offline   Reply With Quote
Old 03-15-2015, 07:03 PM   #14
WolfWhistle's Avatar
Bought a Condor off ebay. Don't see a reason to secure to floor, went 3000 miles and it didn't move. The rear tire is another story, it wants to move to the right or curb side. I have a simple fix now, but haven't tried it out. One mistake I made was to adjust for a smaller tire, and it took two men and a boy to get the bike off of it. I loosened it up and it works great. Whether this one or a different brand they work great for holding the bike during an oil change. Like this one:
Condor Pit Stop Model Motorcycle Wheel Stop Chock PS 1500 Aluminum | eBay
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-16-2015, 07:11 AM   #15
Thank you all for your replies. I will be trying out the HB free standing model sometime this spring when I get the TH. I will report back on my experience then.
Happy camping...
stevejd235 is offline   Reply With Quote
Old 03-16-2015, 11:15 AM   #16
My WheelDock chock I used the mounting plates, the front plates would fit under the floor between the fuel tanks and the water tank, the rear plates are above the water tank I mounted those countersunk into the floor with threaded anchors and 1/4 inch bolts. There is room between the bottom of the floor and the top of the water tank for screws or bolts.
wrsmsgt
2012 HD 2500 DuraMax
2015 XLR ThunderBolt 340x12hp
wrsmsgt is offline   Reply With Quote
Old 03-17-2015, 03:49 PM   #17
Harleyrider
Made a T-shaped anchor that would tie down to the D rings then bolted the chock to it.
harleyrider03 is offline   Reply With Quote
Old 03-17-2015, 03:51 PM   #18
Harleyrider
This is a picture of it .
Old 03-17-2015, 05:02 PM   #19
That's right smart.
breezyhillfarm is offline   Reply With Quote
Old 03-17-2015, 05:18 PM   #20
Jestercyco's Avatar
On my old TH I used the ones from harbor freight on my roadkings. I put a flatbar between the 2 bikes and used the d rings in the XLR. No attatchment to floor. Worked fine except like said before on baggers, the fenders were tight. I machined the tire holder on bottom by .5 inch to clear the fender.
jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
