Old 02-13-2013, 08:54 AM   #11
As you can see in the front, if you look to the left, on the underside of the cabinet, you can see the holes where the mount previously was. I removed it from that location and moved it to the wall but the bracket is still mounted to the underside of the cabinet. I had to modify the mount by tightening the bolt at the swivel point. It is tight enough that it takes a good amount of force to make the tv swivel back and forth. The only other thing i need to do is add the piece of wood to the inside of the cabinet and put bolts through to add more stability to the mount.
The mount in the rear garage area is where the factory put the mount. I have not inspected where the studs are.
Name:	front bedroom tv mount.jpg
ID:	24285   Click image for larger version
Name:	rear tv mount.jpg
Martins5547 is offline   Reply With Quote
Old 02-13-2013, 12:38 PM   #12
10x
I like the front mount. Any idea where that tv bracket is sold?
10x is offline   Reply With Quote
Old 02-13-2013, 08:32 PM   #13
Got the brackets from the factory like this. no idea where they got them from. sorry.
