Old 02-19-2013, 07:31 PM   #21
coderider's Avatar
I picked up a pair of chocks from harbor freight (http://www.harborfreight.com/motorcy...ock-97841.html). The price is great and the hold a Honda VTX 1300 and 1800 rock solid.
coderider is offline   Reply With Quote
Old 02-19-2013, 09:02 PM   #22
10x
Originally Posted by coderider View Post
I picked up a pair of chocks from harbor freight (Motorcycle Stand / Wheel Chock). The price is great and the hold a Honda VTX 1300 and 1800 rock solid.
How do you have them mounted in the trailer?
Do have them bolted down?
10x is offline   Reply With Quote
Old 02-19-2013, 09:06 PM   #23
coderider's Avatar
Don't have them bolted down. Ratchet strap the rings front/back to the toy hauler tie downs to keep it from moving around. Also strap the bike handle bars like normal to the floor tie downs and the rear tire like you would on a trailer.
Sits tight.
Old 02-19-2013, 09:29 PM   #24
10x
Sits tight.
If you can, can you please post some picks of how you have your bike tied down. I would like to use an option where I don't have to bolt them down. Plus thats a great price.
Old 02-20-2013, 06:22 PM   #25
coderider's Avatar
Next time we put them in will try to remember to et those pix.
Old 02-20-2013, 08:26 PM   #26
10x
Sits tight.
When you ratchet them down do you only use the 2 eyelets the chocks come with, or did you add 2 more?
Old 02-21-2013, 12:31 AM   #27
1l243's Avatar
I looked under my buddies XLR and if I remember right the sealed underbelly looked like a nylon web type material? Is there enough slack in the material to push up on that material from underneath and touch the bottom of the plywood floor? The condor mounting bracket comes with approx 5" long tapered pan head screws. If they are not long enough you could get some longer ones that would push through the underbelley material, use fender washers and then cut off the excess once tight.
As mentioned above watch out for water tanks......
I have the Condor wheel chock and it's a nice chock.
Harbor Freight does sell a similar style roll in locking chock for a lot less money but it does not have the mounting plate like the Condor..
1l243 is offline   Reply With Quote
Old 02-21-2013, 06:31 PM   #28
coderider's Avatar
Use the ones on the chocks, didn't add anything. Could probably get away just timing those rings to the rear tied owns since the handlebars are tied down to the front ones. With the bike in that thing is very snug.
Old 02-21-2013, 06:57 PM   #29
pjones1969's Avatar
Not a wheel chock but I use the B&W Biker Bar, its nice, due to the location of the freshwater tank and fuel cell in the Puma 27sbu this worked out to be 3 inches off of the fuel cell wall, I drilled all the way through and made some flush mount hardware so I can take it out if we go without the bike.
http://www.turnoverball.com/products/motorcycle
2011 Puma Unleashed 27SBU - SOLD
2013 Sabre 32bhok-6 - SOLD
2012 Ford F250 6.2 - SOLD
2017 Heartland Cyclone 3800
2016 Ford F350 6.7 DRW
B&W Companion
pjones1969 is offline   Reply With Quote
Old 02-21-2013, 07:11 PM   #30
10x
Motorcycle Trailering | B & W Trailer Hitches
Does it come with the removable hardware?
chocks, motorcycle, mounting, mounting chocks, toy hauler
