I bought the same unit have owned it less than two weeks, here are the major problems I found wrong so far
Back water valve leaks
Fantastic fan in the galley only has power when the lights are on.
Front Bedroom window scratched frame and bent
Look at the front corners of the front cap, where its mounts to the sides. I found cracks in the gel coat, my fear is it will spread.
Last big concern I found a air bubble in the front cap near the top right marker light. Size of a silver dollar, I can move it around by pushing on it.
We hand waxed ours and covered every inch, it's a lot of work but that's how you find all the flaws.
I put a shock on the back door also, if the door were to open all the way it smacks into the awning brackets.
I am wondering what the hell did I get myself into.
