Old 06-01-2016, 12:57 PM   #61
mrpep's Avatar
How old were the tires ?
mrpep is offline   Reply With Quote
Old 06-01-2016, 01:57 PM   #62
NMWildcat's Avatar
First time - just over 2 years China bombs
Second time - 18 months Firestone lts
Old 06-01-2016, 02:01 PM   #63
Had the same problem on my F250. Had Goodyears on it and all was good, Switched to Michelins and the truck was all over the place. No other changes, just the tires.
Never figured it out just ran the Michelins untill i sold it 6 months later.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 06-01-2016, 02:14 PM   #64
mrpep's Avatar
Wow, I just put China bombs on mine . The only thing that gives me some kind of peace is that the are load D and I have a double axle so these tires are a bit overkill since I'm only hailing maybe 5k lbs. Hope things go well. Here's another question, are your tires radial? I guess one has the stronger sidewalks than the other type?
Old 06-01-2016, 03:04 PM   #65
NMWildcat's Avatar
Yep radials. The light truck tires had better side walls if I remember right. Not enough left of any of the tires to show cause of failure.
Old 06-02-2016, 04:36 PM   #66
bmallak's Avatar
To the OP, I tow my 305VL5 with a 2015 3500 with 18" michelins and have no issues.
2017 XLR Nitro 305VL5
2015.5 GMC 3500 CC SB Z71 6.0
Super Glide 4400
bmallak is offline   Reply With Quote
Old 06-03-2016, 09:04 AM   #67
I do 60 to 65 comfortably if someone doesn't like it I'm sorry but my tires are rated for 60 max and I'm gonna be safe. And I could put money on it that this is not a crime so as long as I'm within the limits of the law , the road hog road ragers will have to just deal with me , sorry
I talked to a NY State tropper on the NY Thruway this winter on my way to Florida and he said the biggest cause of TT rollovers and accidents is people travelling at 70+ mph. They cant stop and then sway and just roll over when they get into trouble which may not be of their making. He said stay within the 60+ mph range and be safe. I had a blow out and never even noticed it at that speed and he said another 10mph it may have been a different story. A professional that sees lots of accidents.
bruane is offline   Reply With Quote
Old 06-03-2016, 09:05 AM   #68
mrpep's Avatar
Kinda scary , were you maybe maxing out the capacity of the tires with weight and speed ?
Old 06-03-2016, 09:07 AM   #69
mrpep's Avatar
Good to know and it's so easy to get up to 70 cause you get comfortable and look at odometer and that's when you realize your at 70, it happened to me this weekend. I truly like 60 and you've convinced me that that's probably the safest limit.
Old 06-03-2016, 09:53 AM   #70
Rupkin2's Avatar
Originally Posted by Springerdad View Post
How did we get from a handling issue with a new truck to how fast we drive and how safe it is and TT tire speed ratings?
Just askin'
Haven't finished reading all the posts yet, curious if OP (Boosted1200)found his solution.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
truck
