Old 05-30-2016, 10:08 PM   #1
New truck now pulling problems.
Old truck was a 2015 gmc 2500 srw pulled awesome, no problems at all at any speeds. New truck is a 2016 gmc 3500 srw now when pulling it sways all over the place. At 70 you can just feel it floating side to side never had this problem with the 2500. The only difference from the 2500 to 3500 is a added leaf spring bump stops and 18s instead of 20s.
Any thoughts on this?
Boosted1200 is offline   Reply With Quote
Old 05-31-2016, 07:48 AM   #2
Always Learning
Is there an increase in height? Are you now towing nose high?
Old 05-31-2016, 08:16 AM   #3
Brother Les's Avatar
Most likely need a little adjustment on your hitch to find your sweet spot again.
Brother Les
Old 05-31-2016, 08:24 AM   #4
More sidewall on the 18" tires than the 20s?
ricky836 is offline   Reply With Quote
Old 05-31-2016, 08:26 AM   #5
WolfWhistle's Avatar
Trailer? Hitch? tongue weight? 70? Photos?
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 05-31-2016, 08:33 AM   #6
dieselguy's Avatar
Have you checked your new truck's tire pressure? My truck gets squirrley if I bump up the tire pressure to max as stated on the sidewall and not what's stated on the door sticker.
dieselguy is offline   Reply With Quote
Old 05-31-2016, 08:35 AM   #7
Are you running a more aggressive tread pattern on the TV tires now?
Old 05-31-2016, 09:58 AM   #8
northstar1960's Avatar
What changed besides the truck . hitch height ? TW , i've got an old chevy 2500 16" rims run 80psi towing . never any issues tow like a dream . something simple changed causing your problem . i would not think the rim size is making a difference . i think brother les is right hitch adjustment
northstar1960 is offline   Reply With Quote
Old 05-31-2016, 11:01 AM   #9
I went from 2006 2500hd srw to 2016 2500hd srw I had to lower the ball height
2015 hyper lite 29 hfs / 2016 gmc 2500hd
lonb is offline   Reply With Quote
Old 05-31-2016, 11:09 AM   #10
I never measured the height in the last truck so I don't know what that was. The trucks sat the same side by side at the dealer. I'll take a pic and post to see what you guys think
Old 05-31-2016, 11:17 AM   #11
Someone else mentioned it, the 18's have a taller sidewall and you may have more flex there. Are your tv tire pressures at their max?
Also, if the tires are brand new there will be some squirm there too.
Springerdad is offline   Reply With Quote
Old 05-31-2016, 11:25 AM   #12
buckaroo2's Avatar
I have a new 3500 chevy and yes the height between the 2500 and 3500 difrence could be a problem adjust the hitch height or get a diffrent lower trailer reciever
buckaroo2 is offline   Reply With Quote
Old 05-31-2016, 11:28 AM   #13
hbdiver's Avatar
Park your truck and trailer on level surface. Then with the truck uncoupled measure fender height front and back. Measure trailer height front and back. Be sure trailer is level as well. Hook up everything and check heights again. Front of truck may be a smidgen higher than the back but not lower. Same with back a smidgen lower but not much.
hbdiver is offline   Reply With Quote
Old 05-31-2016, 11:29 AM   #14
D_B Travelers's Avatar
Boosted, I'll wager that the new 3500 is taller at the hitch than the 2500 and you are towing nose high now. I agree with others that this is a hitch adjustment issue, I had to drop my Equalizer hitch all the way to the very bottom holes when I changed to a 3500HD to keep the TT level. I have 18" wheels also, but with 80 PSI, I don't think sidewall flex is actually an issue. I would pull the entire rig somewhere flat where you can look at it from a distance and see if it is sitting level; I'll bet it isn't. Do some measurements from trailer frame to ground and see what you have.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 05-31-2016, 11:35 AM   #15
hbdiver's Avatar
I have two 2500s 2006 and 2007 I have two trailers and if I try and tow the smaller trailer with the truck I didn't set the hitch up for I can definitely feel the difference.
Old 05-31-2016, 11:56 AM   #16
I find it interesting that people buy really big trucks so they can pull a trailer at 70 MPH.
I bought the smallest F150 I could to pull the 26 foot trailer at 55 MPH and it works just great.
Must be fun watching the gas gauge drop as you drive
RussPastuch is offline   Reply With Quote
Old 05-31-2016, 12:16 PM   #17
I guess I missed where the OP said they wanted to pull at 70...my bad.
Old 05-31-2016, 12:26 PM   #18
hbdiver's Avatar
I would guess my fuel economy while towing is between 9 and 10 mpg. That is pretty good for dragging around 14,000 pounds through the Rockies and the Sierras. My 2500 is just the right size for my trailers a 32 foot and a 35 foot. T34SP 2006 Been traveling enough to have over 100,000 miles on a toy hauler. Just had to replace the roof May 2016.
Chino Hills, California.
Old 05-31-2016, 12:41 PM   #19
The speed limit here is 70 and is 3 lanes, so yes i pull it at 70mph im not one to drive 55 in a 70 and make everyone go around me. The last truck did it fine. I have more to worry about then fuel milage in my life but thanks for the help.
Old 05-31-2016, 12:46 PM   #20
Trailer is a 39dks5
truck
