Old 05-25-2015, 08:49 AM   #1
CUZISA2
Newbie help!
We're getting ready to go home and want to empty the tanks. The black water won't empty when the valve is pulled. It is 2/3 full and I'm not sure why it won't go. We do have a black water flush so I'm not sure if I'm doing something wrong. Help!
mgmalm is offline   Reply With Quote
Old 05-25-2015, 08:52 AM   #2
Todouble's Avatar
Does it feel like it's sliding open the valve? Try opening and closing a bunch of times and see if it cuts loose. Maybe the valve stem is not attached properly?
Todouble is offline   Reply With Quote
Old 05-25-2015, 08:53 AM   #3
UmptySquat's Avatar
As soon as it's pulled it should start to flow. Doubt it'd be blocked so it's probably the valve not opening.
2013 Toyota Tundra 5.7L
2015 Apex 288BHS
UmptySquat is offline   Reply With Quote
Old 05-25-2015, 08:54 AM   #4
Or maybe debris from when they cut into the tank is blocking it. Check on this site about others who experienced this.
Good luck,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 05-25-2015, 10:04 AM   #5
CUZISA2
Figured it out! I have a second valve on the other side of the camper behind the entry stairs. Once I pulled it and then pulled the main one it all worked. I'm learning!
newbie
