Old 05-15-2016, 08:37 PM   #1
scook's Avatar
Newbie question about fuel tank
We tried filling our fuel tank for the first time and the gas station pump kept turning off. When filling the fuel tank dose the pump need to be turned on at the main panel or at the fueling station? Is there any other reason we would be unable to put fuel in the tank? This is a new Nitro 28KW we are trying to fill for the first time.
Thank you for your help.
scook is offline   Reply With Quote
Old 05-15-2016, 08:50 PM   #2
Jeff Auton's Avatar
I am on my second XLR and both were slow to fill. Just go slow.
Jeff Auton is offline   Reply With Quote
Old 05-15-2016, 09:12 PM   #3
Chrism28's Avatar
Turn the nozzle sideways the fill neck is almost flat so it doesn't run down hill like a care sometimes the breather will fill up with fuel making it difficult to fill
Chrism28 is offline   Reply With Quote
Old 05-15-2016, 09:25 PM   #4
Yep, Another fine design by FR! As already stated, the fill hose is almost flat and level with the top of the tank. Even when trying to add fuel from a gas can it pours out side and all down the skirting. I finally used a long hose and a funnel. Another case of the design personnel never using these fine TH's. IMO I might add!
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 05-15-2016, 10:00 PM   #5
17Racer's Avatar
I also have a slow fill motorhome and with most pumps setting the gasoline handle will just make it click off or shutdown. Holding it by hand on a slow feed is tiring and even difficult at some stations to keep it slow enough.
But I have the fix!
My pen knife is flat sided and is exactly .450 of an inch thick. I slide the knife under the pump handle to keep it open and it feeds slowly. Doing this is completely safe as the gasoline pump handle will always still shut down when filled. No reason to worry just get yourself slightly less than a inch (or .450) piece of wood and give it a try.
2014 Forester 2301 - Chevy
17Racer is offline   Reply With Quote
Old 05-16-2016, 12:57 PM   #6
F350TH's Avatar
Some brands do raise the filler neck, but then you have a box built in to the garage for it taking up floor space. So it's give and take I guess...
2015 XLR Nitro 39DKS5 Toy Hauler
Towed by 2016 Ford F350 CCLB DRW 6.7
F350TH is offline   Reply With Quote
Old 05-16-2016, 03:47 PM   #7
scook's Avatar
Thank you for the suggestions we will give it a try this weekend.
Old 05-16-2016, 06:58 PM   #8
chpence1's Avatar
I took one of the tanks out of our 380 Amp.
We had so much trouble with filling and using from it .....
We had same problems as others.
After removal noticed that both fuel tanks are as low as possible while still within frame. Noticed that there was at least 6 or more inches of open space above tanks. I also noticed that, yes, the fill tube is essentially at the same level as the tank, even though it could be 4 or more inches higher up.
The other thing that effects functionality is how shallow the tanks are.... they are only about six inches deep while the length is the space between the frame rails.
Any side to side tilt of the trailer will cause fill problems and draw out problems.
I don't know if you call this poor engineering or poor construction.
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
Old 05-16-2016, 07:00 PM   #9
northstar1960's Avatar
i turn the pump handle upside down and fill slow . take awhile to get the full 20 gallons but it works with out spillage
northstar1960 is offline   Reply With Quote
Old 05-16-2016, 11:17 PM   #10
Stealth13's Avatar
^^^^ this one we have the same issue with a 2013 stealth
Stealth13 is offline   Reply With Quote
newbie, tank
