Old 04-22-2018, 08:25 PM   #1
Newbie. What is this?
Just purchased a 2015 27HFS. LOVE IT so far. Anyone having problems with the USB charge port in the front bedroom. My second.one has gone out now. Also, in the bathroom, there are two switches...one for the overhead light, and idk about the other one. It does something bc I can make out that the lights dim a little but that's about it. I am also having troubles with the Co2 detector going off while the water tank is heating. Turn it off, air it out and Co2 is happy once again. Seems to be working alright. Any ideas?
Mygodrulz is offline   Reply With Quote
Old 04-22-2018, 08:31 PM   #2
Capt. Mike's Avatar
Welcome and congratulations on your new camper.
The 2nd switch in the bathroom may operate a ceiling fan, and the motor may be bad on that fan, thus you see your light dim as the fan tries to start. Do you have a ceiling fan, and does it work?
CO2 detectors can go bad, although generally not in 2 to 3 years, but I've seen them do so. Not expensive to replace. We used to have to do them in our boat every couple of years. IIRC, less than $20 for a new one, cut two wires, splice in the new one and you are good to go. Might not be a bad idea to change it.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
ďIt's not how old you are, it's how you are old.ĒJules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-22-2018, 08:48 PM   #3
Try again
Tried that. There is a switch up on the fan itself that turns the fan on and off and the switch doesn't effect.it. If the detector is going out, then why does it only go off when the water heater is burning?
Old 04-22-2018, 09:01 PM   #4
Oaklevel's Avatar
Are you using the water heater on electric or propane? If only on electric the detector should not go off, but if you are using the water heater on propane the detector can go off esp. if the outside door is open.
Not sure what idk or bc is or means ?? .......
By the way welcome to the Forum...
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 04-22-2018, 09:28 PM   #5
If you have the Extreme Weather Package (slightly exaggerated name for it) the second switch in the bathroom is for the holding tank heaters. If not then I donít know (idk!). Welcome to the forum and congrats on your new purchase. Lots of good information on here.
DennisTD is offline   Reply With Quote
Old 04-22-2018, 09:30 PM   #6
Just as confused as you
Scrapper's Avatar
I have 2 switches in my bathroom, one is for the vanity lights, the other is the ceiling light and vent fan. Both the ceiling light and fan have switches built-in so I turn that one off and use the switch on the wall for the fan and leave the fan switch set to the speed I want. When using the fan be sure you have the vent open.
Mygodrulz: "Not sure what idk or bc is or means ?? ......."
IDK = I Don't Know, bc = because.
Richard & Jill
Camping since 1989, seasonal since 2000
Car Shredder Operator/Technician, Scrap Metal Recycling - retired
Scrapper is online now   Reply With Quote
Old 04-23-2018, 02:17 AM   #7
Scrapper's Avatar
Oaklevel, maybe this will help.
Acronyms
4X2 = 2 Wheel Drive
4X4 = 4 Wheel Drive
4WD = 4 Wheel Drive
5er = Fifth Wheel
5r, 5R = Fifth Wheel
5ver = Fifth Wheel
A/C = Air Conditioner
AC = Alternating Current as in 120VAC (sometimes mistakingly used for air conditioner)
AFAIK = As Far As I Know
AMP = Amperes
ATF = Automatic Transmission Fluid
ATS = Automatic Transfer Switch (from shore to generator power)
BC = Brake Controller
BLM or BOLM = Bureau Of Land Management
Break-A-Way, BreakAWay = emergency brake switch on Trailer, either Fifth Wheel, Travel Trailer or some Pop Up trailer
BTW = By The Way
BW = Black water (sewer), BW tank
CAPS = Capital Letters. Using all CAPS is considered SCREAMING
CC = Crew Cab of a TV (4 Door)
CCC = Cargo Carrying Capacity
CF = Camp Fire
CG = Camp Ground
Class A = bus style motorhome
Class C = motorhome with a truck or van style cab
City water = a pressurized water supply, whether city, town, country or campground
COE = Corp of Engineers (US Army)
CRS = Can't Remember Shi... Dang CSR, I forgot the next letter
CTD = Cummins Turbo Diesel (Dodge)
CW = Camping World
D/A = Duramax/Alison (Chevrolet or GMC)
DC = Direct Current as in 12VDC
DH = Darling Hubby or Husband, Dear Hubby, Da%& Hubby, Designated Hitter (baseball)
Dinghy = See Toad
Dmax = Duramax diesel (GM)
DRW = Dual Rear Wheels
Dooley = Dual Rear Wheels
DS = Dump Station
DSL = Digital Subscriber Line
DSS = Door Side Scare "light" (see ODS)
Dually = Dual Rear Wheels
DP = Diesel Pusher as used in an MH
DW = Dear Wife, Darling Wife, Da%& Wife, Dim Wit, Dish Washer (same as Dear Wife), Darryl Waltrip (NASCAR)
DZLCD = Dual Zone LCD thermostat made by Dometic for larger units (two zones)
EC = Extended Cab of a TV
EPDM = Ethylene Propylene Diene Monomer (Rubber Roofing)
ERS = Emergency Road Service
ESP = Extended Service Plan
FAQ or FAQs = Frequently Asked Questions
FHU = Full Hook Up (also see WES)
FIVER = 5th Wheel
FR = Forest River
FRF = Forest River Forums
FROG = Forest River Owners Group
FT = Full Time camper (sometimes F/T)
Furry Kids = Pets
FW = fresh water, often FW tank
FW = Fifth Wheel
FWIW = For What It's Worth
FYI = For Your Information
G8R = Gator
GOB = Good ol' Boy
GPS = Global Positioning System or Satellite
GAWR or GAW = Gross Axle Weight Rating
GCVW or GCW = Gross Combined Vehicle Weight
GCWR = Gross Combination Weight Rating
GTWR = Gross Trailer Weight Rating
GVW or GVWR = Gross Vehicle Weight Rating
GW = Gray/grey water (sinks, shower drainage), GW tank
HD = Heavy Duty
HH = Happy Hour
HWH = Hot Water Heater (Why would you heat hot water?)
HW = hot water, HW tank, HW heater (a misnomer for water heater)
IBSRV = International Brotherhood/Sisterhood of RVers
IIRC = If I Remember Correctly
IKR = I know right
IMHO = In My Humble Opinion
IMO = In My Opinion
IP = Internet Provider
ISP = Internet Service Provider (sometimes written DISP = Da$& Internet Service Provider)
L8R = Later
L8R G8R = Later Gator
LMAO = Laughing My A__ Off
LB = Long Box or Bed of a Tow Vehicle
LOL = Laughing Out Loud , Lots Of Luck, Lots Of Love
LP = Propane Gas also Liquid Propane Gas
LT = Light Truck tires(as in LT245 tires)
MBS = Mercedes Benz Sprinter Diesel Chassis and is formerly known as the Solera Class C RV
MDT = Medium Duty Truck
MIL = Mother in-law (other in-laws can be FIL,BIL, SIL, and DIL)
MOC = Montana Owners Club
MH = Motor Home
MTCW = My Two Cents Worth
NCC = Net Carrying Capacity
NPS = National Park Service
OALAEHO = Opinions Are Like A__holes, Everybody Has One
ODS = Opposite Door-side Scare "light" (see DSS)
OEM = Original Equipment by the Manufacturer
OHC = Overhead Cabinet
OMG = "what have I gotten myself into"
OP = Original Post or Original Poster
OPD = Overfill Prevention Device (on LP gas cylinders)
PDI = Pre-Delivery Inspection
PM = Private Message
PSD = Power Stroke Diesel (Ford}
PU = Pop Up trailer
PUP = Pop Up trailer
PUGS = Pop Up Gizmos (reflective covers for tent campers)
PW = Pressure Washer
Qs = Question(s)
QC = Quad Cab, 4-door or Quality Control
RGV = Rio Grande Valley
ROTFLOL = Rolling On The Floor Laughing Out Loud
ROTFLMAO = Rolling On The Floor Laughing My A__ Off
RV = Recreational Vehicle
SB = Short Box or Bed of a Tow Vehicle
SCWR = Sleeping Capacity Weight Rating
SKP = Escapee
SOB = Some Other Brand (of RV)
SP = State Park
SRW = Single Rear Wheels
ST = Trailer tires (as in ST225)
SZLCD - Single Zone LCD thermostat made by Dometic for smaller units (larger units usually have two zones)
TC = Truck camper
TH = Toy Tauler
TMI = Too Much Information
TOAD = A vehicle towed behind a MH
TP = Toilet Paper
Trlr = Trailer
TT = Travel Trailer
TV or T/V = Tow Vehicle
tv = television
TW = Tongue Weight
TWR/TLR/VLR = Tongue Weight, Tongue Load, Vertical Load Rating
VIN = Vehicle Identification Number (Serial Number)
URL = Uniform Resource Locator (WWW Address)
UVW or UVWR = Unloaded Vehicle Weight Rating
WallyDock = A seasoned RVers term for parking your RV overnight at Walmart
WallyWorld = WalMart
WD or W/D = Washer/Dryer
WD = Weight Distribution (hitch)
WD/SC = Weight Distribution (hitch) with Sway Control
WES = Water/Electric/Sewer
WH = Water Heater
Wi-Fi or WiFi = Wireless Fidelity
WWW = World Wide Web (the Internet)
X2, X3, etc = Ditto, with the number representing your agreement added to the number of times it was stated beforehand. Also used +1, +2, etc.
YMMV = Your Mileage May Vary
YRMV = Your Results May Vary
And Finally....
HTH = Hope This Helps
Richard & Jill
Old 04-23-2018, 06:18 AM   #8
Switches
IDK=I Don't Know and BC is because. Sorry...didn't mean to confuse anyone. I guess the extra switch could be and extreme weather package tank heater but there is no markings on the trailer indicating that it is one. The switch also has no effect on the vent fan. And yes, the water heater was on propane but I still shouldn't be getting Co2 inside of trailer making the detector go off.
Old 04-23-2018, 06:26 AM   #9
Do you have dual pane windows (you have to look carefully as the two panes are close together)? If yes then you have the Extreme Weather package and the switch is the tank heaters. If single pane then no clue what the second switch if for.
Old 04-23-2018, 06:43 AM   #10
klickitatjim's Avatar
It's likely a CO alarm not a CO2 alarm, unless you are a large scale brewery.
klickitatjim is offline   Reply With Quote
newbie
